Rear leaf lift 1.5" from aftermarket leaf shackles?
Old Aug 20, 2015 | 08:58 PM
02Goldie_Loks's Avatar
02Goldie_Loks is on a distinguished road
Default Rear leaf lift 2" from leaf shackles?
Anybody had luck with leaf shackle lift?? I have a 02 Blazer 2 door.
Old Aug 20, 2015 | 11:34 PM
TMM217's Avatar
TMM217 is on a distinguished road
Well no back luck with mine. If you do decide to install them start soaking the bolts now with PB. Hardest part is getting old ones off.
Old Aug 21, 2015 | 12:26 AM
Sounds like a good idea. Found some on eBay for a 2" lift.
BTW Did you do the swap? I was thinking it'd be easy enough for my 2 jack stands and a floor jack. I have pretty much all basic hand tools.
Thanks
Old Aug 21, 2015 | 08:35 AM
El_Beautor's Avatar
If the bolts will come out of the bushings then it's an easy driveway swap. Like TMM217 said, the hardest part is getting the bolts out.
Old Aug 21, 2015 | 05:21 PM
Thanks!
So just use the floor jack on the rear diff to lift things then put the jack stands under the axle housing one for each side of the diff?
Or underneath the shock absorbers?
Thx for the help!
Old Aug 21, 2015 | 08:19 PM
AJBert's Avatar
No, you want to put the jack stands on the frame to remove any tension on the axle and leaf springs. Otherwise, you'll never get the bolts out even if the bushings are good.
Old Aug 23, 2015 | 04:45 PM
Thanks!!! I'm sure the bushings are good. They make no noise. Could I use the old bushings on the new 2" lift shackles? Or do new shackles come with new bushings?
Old Aug 26, 2015 | 10:25 AM
El_Beautor's Avatar
If you don't destroy the old bushings, and they're in decent shape you can reuse them. The bushings are in the springs, not on the shackles.
Old Sep 11, 2015 | 05:47 PM
clicheche's Avatar
clicheche is on a distinguished road
Thanks
Just swapped mine out. Def soak bolts on shackles top and bottom. It was a coupke hrs. Some tight spots hand tools are ideal in spots. Air gun (vibration) will help loosen accesible ones
cpolson.cp
Aug 23, 2015 05:47 PM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
