rear lift... help
Old Sep 12, 2011 | 04:25 PM
kreep_66's Avatar
kreep_66 is on a distinguished road
Default rear lift... help
Ok so I got a 01 blazer 4x4. I just got some lifting blocks. I just realized the leaf springs are under the axle....
So I was wondering other than shackles what can I do??
Thanks in advance.
Old Sep 12, 2011 | 05:42 PM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
You could do a leaf over axle conversion. I believe that will give you about 4-6 inches of lift in the rear end, then you just have to figure out what to do in the front.
Old Sep 12, 2011 | 10:31 PM
Blazer Spike's Avatar
Blazer Spike is on a distinguished road
Not it would not be that much. More like 2-3" of lift. I'm going to be doing mine soon on my 03 if I don't find shackles to use.
Old Sep 12, 2011 | 10:39 PM
NVANZEE's Avatar
You can use either shackles or an add-a-leaf. Flipping the axle under the leafs will get you about 5in. Thats what all the big suspension kits do like mine
Old Sep 13, 2011 | 01:17 AM
kreep_66's Avatar
Cool thanks.
I wanna do the leaf conversion but
Like snowboarder said idk what to do about the front.
Old Sep 13, 2011 | 09:36 PM
Well for the front end, if you're really ambitious, you could do a solid front axle upgrade. Or you could get one of the aftermarket suspension lifts for the front end. IMO I would go with the solid front axle, much better than the IFS if you are going to do heavy off roading
Old Sep 14, 2011 | 11:48 AM
kreep_66's Avatar
Yea I've thought of the.solid front axle. But I'm lacking on the funds...
But I was looking online for any shops that might sell lifting kits for blazers maybe its just me but I couldn't find anything.....
The only things I found were torsion keys and a body lift..
Old Sep 14, 2011 | 12:14 PM
NVANZEE's Avatar
yeah the only suspension lifts are 2, 5, or 6in. the 5 and 6 are expensive though
Old Sep 19, 2011 | 06:44 PM
kreep_66's Avatar
Alright cool thanks for the help guys. I still need to figure out what to do but this was a big help.
Old Sep 19, 2011 | 07:01 PM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
what are you trying to accomplish? more clearance under the vehicle? to run bigger tires?
if all you are looking for is to run bigger tires then just do a body lift. the cost is reasonable
if you are looking for clearance under suspension then do 2in shackles and a tbar crank
