rear wheel wobles
Old Aug 25, 2011 | 08:58 AM
chimacc's Avatar
chimacc is on a distinguished road
Default rear wheel wobles
was told i need new wheel bearings and seal when replaceing iam going to do both is there any thing else i should replace like Axle Differential Bearing or anything else
1996 Chevrolet Blazer LS
any part numbers would help too
Old Aug 25, 2011 | 01:43 PM
pettyfog's Avatar
What do you mean 'wobbles'? When you're driving down the street, you can see it wobble?? Like the wheel was bent?
That's an AWFUL bad bearing. The noise alone... plus you'd have rear axle fluid everywhere.
Or when you lift wheel off ground you can shake tire and it moves sideways a little.
Bottom, line unless the differential is making noise, probably dont have to replace that 'differential bearing'.
Part #.. use this site: {court Giovanni}
Car parts for your Buick, Cadillac, Chevrolet, Hummer, Light Truck, Oldsmobile, Pontiac, and more!
Old Aug 26, 2011 | 12:30 AM
chimacc's Avatar
when I lift wheel off ground I can shake tire and it moves sideways a lot and when driving it makes noise and not sure what to buy was told there is a inner outer bearing + seals and the whole back axiel will have too come off and also would have 2 drain gear oil and refill it with more not even sure how much gear oil i will need and thanks frog for replying the mechanic i talk too works only with disel truck semis but said he do the job for free i i bought all the parts not really sure what to buy
Old Aug 26, 2011 | 10:54 PM
Rottidog's Avatar
Hmmm if the wheel wobbles like that maybe look to the wreckers for a used axle with the same gearing. Then after a 30 min or so R/R you'd have to get an alignment. A rear axle shouldn't cost more than $200, but keep in mind that used is you get what it is. Try to make sure it's from a low mileage vehicle with no rear end or side by the rear wheels damage.
<edit> a '78 blazer with a rear end issue? I'll trade you mine + you give me $7000 lol I'd love to have a '78 blazer
Old Aug 27, 2011 | 12:43 AM
pettyfog's Avatar
Yeah. If you need that inner/differential bearing and If the tread on the tire moves more than 1/8 inch or so, you may as well replace the whole thing.
The axle bearing surface would probably be damaged as well, meaning new axle. And if that inner bearing is bad, there are going to be other problems too.
How's the bearing on the other side?
So you're saying the guy will do it free if you pull the whole rear axle housing and take it to him? If you're going to all that work, either do the axle bearing and seals yourself on jackstands, or replace the whole thing.
I'd suggest replacing the seals and lube on the used one, too. Of course you will check for slop on those axles.
97 BLAZER REAR END - YouTube
Old Sep 6, 2011 | 08:23 PM
chimacc's Avatar
Default ok
OK i replaced the bearings near the tires did both sides wobble stopped and the axle looked good but i still have the squeak while driving squeak stops as soon as i touch the breaks any ideas great video wish i saw that before had a hard time with the bearings and any videos on you tube with shift cable or coulum shifter for a blazer 96?
Old Sep 6, 2011 | 08:36 PM
Have you checked the runout on the face of the axle flange? Maybe the axle is bent slightly...
Old Sep 6, 2011 | 08:48 PM
chimacc's Avatar
no i dint check that i just look for dirt and the teeth or gears but i staring 2 think the squeaking is from the breaks and i will try to figure out what 2 grease and do a recheck thanks for the help
mirrorimij
Jun 8, 2019 03:34 PM
bigdaddykane93
Tires and Wheels
Mar 21, 2014 03:07 PM
ComputerNerdBD
Tires and Wheels
Mar 5, 2011 05:50 PM
DetailersDomain
Detailing
Jan 21, 2011 07:09 PM
OuttaControlHPC
Mar 5, 2009 06:07 PM
