removing the front differential
Old Jan 12, 2008 | 02:28 PM
tilley101's Avatar
tilley101 is an unknown quantity at this point
Default removing the front differential
i have the passenger side drive axle off now all i need to do is unbolt the differential pumpkin. i can cant get the top bolt at all. the nut is inside the frame is just turning. the nut is an 18mm. there is a hole in the frame to get the wrench in there but its impossible to get it to stay on the bolt. i've had someone hold the wrench while i uses the socket to get it out. ive sprayed with pblaster and still nothing. anyone got any tips on how to get it out?
Old Jan 12, 2008 | 02:44 PM
Default RE: removing the front differential
hot wrench! Seriously, if the nut is rounded off to the point where you cannot keep a wrench on it, then you need to cut the bolt to get things apart.
Old Jan 12, 2008 | 03:26 PM
tilley101's Avatar
i dont think so i can get it around but i think i need an offset wrench.. i found a foot socket so im gonna try that
Drew4711
Oct 6, 2012 12:47 PM
ronaldo
Mar 6, 2011 05:17 PM
mosfetpioneer
Sep 1, 2010 04:59 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
lilred67ddgt
Dec 7, 2005 02:55 PM
