Replacing front pinion seal
Old Sep 2, 2019 | 11:00 PM
Melissa Keith Sechrist's Avatar
Melissa Keith Sechrist is on a distinguished road
Default Replacing front pinion seal
How hard to Replace front pinion seal on 2000 gmc jimmy diamond edition 4.3lt 4d 4wd
Last edited by Melissa Keith Sechrist; Sep 2, 2019 at 11:02 PM. Reason: Adding things
Old Sep 3, 2019 | 10:20 AM
LesMyer's Avatar
It's not really that difficult if you know what you are doing, but once the driveshaft is off there is a big nut holding the yoke on that will be very tight. Then the yoke may or may not need to be pulled off the pinion with a puller tool - some do, some don't. Once the yoke is removed, you pry out the old seal and use a seal installer tool to install the new seal (or if you are experienced you can pound it in with a hammer). Inspect the seal surface on the yoke for wear and replace if any problem. Install the yoke and tighten the nut to maybe 150 ft lbs - something below the torque that will further crush the crush sleeve in the rear end (The original crushing of the sleeve is a critical adjustment so don't want to crush it further - but not so loose that the gears will have extra play). Hope that answers your question.
Kusstard
Oct 12, 2017 03:53 PM
sixgunzx2
Nov 30, 2009 02:38 PM
hubbmatt
May 16, 2009 09:09 PM
ahawks47
Aug 1, 2008 03:00 PM
mikepro
Sep 27, 2007 06:00 PM
