replacing rear end in my 01 blazer
Old Dec 28, 2014 | 07:27 PM
mike2001's Avatar
mike2001 is on a distinguished road
Default replacing rear end in my 01 blazer
i need to replace my rear end in my 01 blazer its a 4.3 liter it has 4x4 its also's an automatic. heres my problem i paid someone to go to the local salvage yard & pick up the entire rear end i was told it would be easier to replace the rear end than mess w/the gears in the pumpkin. so anyways said mechanic took the cover off took all the gears & whatnot out & has yet 2 come back. so now im left 2 decipher with limited knowledge on which is the correct rear end to purchase. im told theres 7.5 & 8.5 i do know theres is 10 bolt pattern on cover and 28 spline i believe. can anyone throw me some advice cause im swimming here.
Old Dec 28, 2014 | 07:41 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
code is in the glove compartment.
Old Dec 30, 2014 | 05:35 PM
mike2001's Avatar
ok ill check the glove box for
that code thank you for your help!
Old Jan 1, 2015 | 05:58 PM
blazerguy09's Avatar
blazerguy09 is on a distinguished road
look at this picture
look at RPO CODES on glove box
also make sure get correct rearend from 4x4 blazer not 2wd or ZR2
because 2wd have narrower rearend and ZR2 have widen rearend.
4x2, 8-1/2" ring gear (3.42 ratio, GU6)
4x4, ZR2 opt (3.73 ratio GT4)
4x4, w/o ZR2 opt; 7-5/8" ring gear, 3.42 axle ratio (opt GU6)
4x4, w/o ZR2 opt; 7-5/8" ring gear, 3.73 ratio (opt GT4)
4x4, w/o ZR2 opt; 8-1/2" ring gear (3.42 ratio, GU6)
4x2, 7-5/8" ring gear (3.42 ratio, GU6)
if your glovebox say G80 that means u have a POSI rearend.
Old Jan 5, 2015 | 02:43 AM
mike2001's Avatar
thank you 4 ur time
doktornasty
Nov 3, 2013 03:12 AM
MXCowboyTX
Mar 6, 2013 01:18 PM
Kemper9388
Aug 24, 2011 11:03 PM
brino1
Feb 25, 2011 08:05 PM
