Shock Nuts (Help!)
Old Mar 20, 2020 | 10:46 AM
ChaosFox's Avatar
ChaosFox is on a distinguished road
Default Shock Nuts (Help!)
Hey i have a 2000 Chevy Blazer 2D 2WD, and i replaced the rear passenger shock just fine, but the driver side rear is a bitch.. one of the too bolts won’t come out BUT IT’S LOOSE. I can fidget and move! I felt on too and theres like a metal tab or something holding it from coming? How did i get this out...
Old Mar 20, 2020 | 05:34 PM
If I remember correctly, there's a nut clip on the crossmember that the bolt threads into. If it's spinning, you might be able to hold the nut part of it up top with a pair ov vise-grips. If not, you may have to cut or grind it off.
Old Mar 20, 2020 | 07:07 PM
ChaosFox's Avatar
Hey Tom, thanks! It was the clip and it came off, i had to weld it back. Thanks much.
Old Mar 21, 2020 | 11:50 AM
Glad to hear it worked out.
As far as the no-new-hardware-included thing goes, those same shocks probably fit several different applications which don't necessarily use the same hardware. Since it would probably cause more problems to give somebody the wrong hardware, rather than no hardware, it makes sense to go with the safest choice.
Zenith
Mar 20, 2020 07:08 PM
c10s10
May 26, 2010 08:30 PM
1987blazers15
Nov 28, 2009 08:52 PM
portcqb
Aug 17, 2009 07:19 AM
Ludachrls83
Apr 21, 2009 07:36 PM
