Shocks
Old Dec 23, 2018 | 12:10 PM
Letholdus0341's Avatar
Letholdus0341 is on a distinguished road
Default Shocks
Hi I am new to the forum. I have a 2000 s10 blazer 4 door ls. I have replaced the torsion keys and rear shackles to achieve a 3.5 to 4 inch lift. I have put 31x10.5r15 on stock rims. My question is do I need to replace the factory shocks and possibly the a-arms?
Old Dec 23, 2018 | 12:31 PM
cleburne red's Avatar
Pretty sure the most you can get from keys and shackles is around 2", a 4" lift shackle would be 8" longer than stock.
Im sure your shocks will be ok, but it's going to put stress on your cv shafts, ball joints, etc. Do some research around here, there's tons of documentation on the various ways to lift your truck.
There's even a really awesome install thread of a rough country 6" lift kit in the off roading section lol
Old Dec 23, 2018 | 12:59 PM
Awesome thanks for the info.
Old Dec 23, 2018 | 01:14 PM
How do the 31x10.50 tires work on stock rims? I'm planning on 33x10.50 after my lift is done. Rough Country says that it will rub with stock rims (6" backspacing) and I need something with 4.5-5.0"
Old Dec 23, 2018 | 01:58 PM
odat's Avatar
I have 31/10.50/15s Hankooks on stock rims on my 4X4 rx7 toy - on super tight turns they touch slightly but not enough to worry about, 33s might be a problem but the width should be the same so maybe not.
Old Dec 23, 2018 | 02:37 PM
My 31's only rub at full turn.
Old Dec 26, 2018 | 01:46 AM
30's do not rub but 31's will with my 2" lift.
I installed the Rough Country upper control arms so that the upper ball joint geometry would be better for the lift.
Old Dec 26, 2018 | 11:28 AM
I was thinking of getting the rc a-arms instead of yhe whole kit being that I already have the torsion keys and rear shackles.
Old Dec 26, 2018 | 11:39 AM
Strangerock's Avatar
Strangerock is on a distinguished road
It is possible that with your lift ....when the suspension fully extends that your shocks may hit the end of travel and prematurely wear out...... It is said that this can happen on a ZR2 with regular shocks so I would think this could happen with your current set up.
Old Dec 26, 2018 | 01:01 PM
That is basically what I did for my lift, minus the new torsion bar keys.
I had to address this problem too. Since one of my front shocks was bad I had an excuse to get two new front shocks that were 2" longer. However for the rear with my funky ZW7 Premium Ride suspension that has softer than normal rear springs supplemented by self-leveling shocks, I instead added spacers to where the shocks mounted to the frame so I could use the original shocks.
I have a link to what I did for my lift below.
