Soild axle converson HELP
Old Nov 3, 2011 | 11:33 PM
Zr2Blazer4107's Avatar
Zr2Blazer4107 is on a distinguished road
Default Soild axle converson HELP
Kay so im doing a soild axle swap on my 2001 Zr2 Blazer and i undersatnd the whole leaf spring conserson and so forth, but i was wondering whats the best axle i should use and how to conect the stock stering to the new axle?
Old Nov 4, 2011 | 11:26 PM
abig84's Avatar
i dont think you can use the stock steering. i dont even think you can use the same gear box. when i did my 93 the pitman arm faced backwards, if you flip it around to make it face forward it will be backwards, like turn left and it will go right backwards. when i did mine i just used a astrovan gear box with the stock pitman arm machined to take whatever tie rod end you want to use, then get some a passenger side flat top knuckle and crossover steering and youre all set. i know it sounds kinda confusing but its really quite simple. even simpler then the stock stuff thats down there.
i really dont have any good pictures of my steering set up but you can see it here. basically its just one bar that runs off the pitman arm that pushes the axle side to side
and encase your wondering those are fullisized k5 blazer axles, so they stick out pretty far, they came off the camo truck to the left
Old Nov 4, 2011 | 11:38 PM
69chevelle's Avatar
69chevelle is on a distinguished road
as for axle, that depends on your plans for the truck.
what are your fab skills, how will you drive your truck, do your tires need to covered, how big of tires, do you want to retain your bolt pattern or do you care what it will be...etc etc.
some common ones are a LP44 out of a wagoneer d30 out of a tj or such, or wider axles such as a p44 out of a late 70'd ford.
if your willing to swap transfer cases then that really opens up our options,
a jeep pitman arm will fit on the stock box but it is still better to use an astrovan box.
chowell
Mar 6, 2021 09:47 PM
thrandall
May 3, 2013 04:54 PM
blajeans
Jan 9, 2013 12:58 PM
LucasMI
Jan 2, 2012 02:15 PM
jmaynard
Jul 12, 2011 01:03 PM
