-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Solid axle swap on 1998 4dr blazer Question (https://blazerforum.com/forum/steering-suspension-drivetrain-36/solid-axle-swap-1998-4dr-blazer-question-55807/)
Racingxtreme8 Feb 24, 2011 04:51 AM
I got a jeep axle and springs for the front but not real sure what to do with the rear haven't been able to find lift spring for it. Anyone no what else can be used.
abig84 Feb 24, 2011 12:35 PM
depending on how high you are going you can just put your axle on the bottom of your springs, when i did mine i just took care of the front then adjusted the rear so it matched the front. so basically all you have to do is take the ubolts off, and reposition the axle under the springs. i know they make lift springs for the older ones
Racingxtreme8 Feb 25, 2011 03:02 AM
I was trying for 6inches that's what got for the front. Thanks for the suggestion I might try that.
