Solid axle swap on 1998 4dr blazer Question
Old Feb 24, 2011 | 04:51 AM
Racingxtreme8's Avatar
Racingxtreme8 is on a distinguished road
Default Solid axle swap on 1998 4dr blazer Question
I got a jeep axle and springs for the front but not real sure what to do with the rear haven't been able to find lift spring for it. Anyone no what else can be used.
Old Feb 24, 2011 | 12:35 PM
abig84's Avatar
depending on how high you are going you can just put your axle on the bottom of your springs, when i did mine i just took care of the front then adjusted the rear so it matched the front. so basically all you have to do is take the ubolts off, and reposition the axle under the springs. i know they make lift springs for the older ones
Old Feb 25, 2011 | 03:02 AM
I was trying for 6inches that's what got for the front. Thanks for the suggestion I might try that.
xillzxnickx
Aug 7, 2014 12:28 PM
bdemutis
28
Mar 28, 2013 02:26 PM
hillbillie559
Jan 19, 2012 01:31 PM
Nightkrawler99
Feb 9, 2008 09:29 PM
sasquatchfound
Jul 15, 2007 05:23 PM
