Some Please Help!!!!!!
Old Jun 1, 2008 | 08:57 PM
sasquatchfound's Avatar
sasquatchfound is an unknown quantity at this point
Default Some Please Help!!!!!!
ok, I replaced the drivers side axle, the upper ball joint, outer tie rod end, new caliper/pads. when i'm driving the drivers side wheel wobbles slightly, and i can hear a knocking sound, but when i put on the brakes it stops. Can some one please help me figure this out!!!!!!!!!!!!!!!!!!!!!
Thanks, shane
Old Jun 1, 2008 | 09:10 PM
Default RE: Some Please Help!!!!!!
A Very bad wheel bearing perhaps??
Old Jun 1, 2008 | 09:35 PM
If by bearing you mean the hub assembly, i inspected it when i took every thing apart and it was still in realling good shape, or is there a bearing in the spindle/knuckle that I'm not aware of? also, i did not replace the lower ball joint, would that have some thing to do with the problem?
Thanks, Shane
Old Jun 2, 2008 | 06:56 AM
Can you see the wheel whoble??
Jack up the suspect corner of your truck and grab the wheel at 12 & 6 o'clock and feel for play by alternately pulling on the top and pushing on the bottom & vise versa.
Wyatt Abshire
Jul 12, 2012 08:27 AM
davidluzader
Mar 1, 2010 10:25 AM
rogggg1020
Nov 11, 2008 08:05 AM
scottyk
Mar 19, 2007 11:32 PM
pdljr04
Aug 15, 2005 04:56 PM
