Squeeky NOISE apon stops and starts
Old Sep 22, 2007 | 07:11 PM
96jimmy4x4in's Avatar
96jimmy4x4in is an unknown quantity at this point
Default Squeeky NOISE apon stops and starts
Hey I currently have a 96 jimmy and when approaching a stop, she seems to have a squeek when applying the brake and basically when the nose dives. Idk if it is the suspension or what but it is pissing me off everytime I stop and people can hear me from a mile away. Please Give Me Some Adivse Towards What I Should Do!
Old Oct 23, 2007 | 11:24 PM
tyson0016's Avatar
tyson0016 is an unknown quantity at this point
Default RE: Squeeky NOISE apon stops and starts
I'm having a similar problem with my '99 S10 Blazer. It makes a little squeaking sound in the passenger side front end area. I only hear it occasionally when approaching a stop. "When the nose dives", as you say. I'll be watching this thread for any suggestions. Thanks.
Old Oct 24, 2007 | 07:08 AM
Have either of you removed the pads and applied any one of a number of anti-squeak compounds to the back surface of the pad to eliminate brake squeal from the equation? This may be the source of your problem.
Other than that, if it sounds like a bushing squeak, then maybe hit the bushings with some silicone spray to narrow things down. Hit the sway bar bushings on the frame as these can squeak if dry.
Old Oct 24, 2007 | 08:48 AM
blazinloud's Avatar
Happend to me once......the squeek was really loud......I Took the spray wand and stuck it in through my rim and cleaned the brakes really good and it stopped.
just an idea......
Old Oct 24, 2007 | 09:30 AM
tyson0016's Avatar
I'll have to wait till the weekend to give these things a try but I'll let you know the results.
Thanks.
familyguy2200
18
May 2, 2011 03:15 PM
vrryder
Apr 8, 2010 08:55 PM
JMAC
17
Apr 7, 2009 11:32 AM
cardsNblazer
Aug 11, 2008 08:26 AM
JMAC
Mar 22, 2008 12:04 PM
