Front end Q's
Old Oct 20, 2007 | 02:01 PM
blazinloud's Avatar
Default Front end Q's
Alright well I went to Mr.lube for an oil change yesterday, and the guy working under my truck said that I have something (cant remember what he called it) leaking up front. He said that if I tryed to put it in 4x4 it would grind really bad.
can anyone give me some insight please?
maybe a rough idea on what needs to be done, and maybe a guesstimate price?
snow is coming and theres no way I wanna be on the highway in 2hi!
Old Oct 20, 2007 | 03:52 PM
cliro's Avatar
cliro is an unknown quantity at this point
Default RE: Front end Q's
is it the fronttransfer case thats leaking.
Old Oct 20, 2007 | 04:54 PM
BigGreenMonster's Avatar
BigGreenMonster is an unknown quantity at this point
I'd say so. If the seal is leaking, its a couple bucks for the seal plus whatever general shop labor is. If the transfer case itself has issues, they run a few hundred for a reman'd.. again, plus shop labor.
Old Oct 20, 2007 | 05:42 PM
thegr81's Avatar
i would say transfer case because thats were 4wd is engaged
Old Oct 20, 2007 | 06:50 PM
Blaze GM4's Avatar
Blaze GM4 is an unknown quantity at this point
I'm guessing since he said "up front" that it's your front diff. Mine has been leaking for the last 5 years or so and since it's such a big deal to change them out i've been putting it off. All i do is keep up fluid levels and change the oil twice a year.
Old Oct 21, 2007 | 12:00 AM
Chevy Lover's Avatar
If it's the front diff....if it's the front diff pinion oil seal it's not a big deal ( about an hour job and a $5 seal)
If it's a diff axle seal it's a bigger job, about 4 hours and a $5 seal.
If it's just a small leak (seeping), just keep an eye on it and keep the diff oil topped up.
Best to find out for sure what is leaking and how bad it is.
Old Oct 21, 2007 | 12:05 AM
thegr81's Avatar
i would go with what chevy lover said plus just get under there yourself and clean around everywhere then wait a lil bit and check back to it unless you can see the leak or were it originated from then go from there
Old Oct 21, 2007 | 01:36 AM
blazinloud's Avatar
thanks for the info guys
Old Oct 22, 2007 | 12:15 PM
blazinloud's Avatar
I'm pretty sure its either 1 of the 2 CL mentiond.
lol, I dont even know where to top up the front diff......ugghhh, lol
my 4 wheel drive dosent work right now anyway so I have to get that done 1st, and then find out why the light is stuck in 4hi.
damn, I've been driving this truck for a little over 2 years, lets see
new battery
new alt
new heater core
radiator
plugs/wires/pcv
fuel pump/filter
and what still needs to be fixed
4 wheel drive
right front ball joint
windshield
drivers side mirror
*possible tranny problems*
flasher
but ya you guys get the point, think I could have payed this off twice now......
Old Oct 22, 2007 | 01:21 PM
drperry's Avatar
sparkies don't count, lol.
Check the left axle seal... Mine was fixed a little while back, so it might start leaking there first, lol.
As for filling it... It's pretty easy to see once you crawl underneath and look... I forget off the top of my head where the fill plug is, but the drain plug is dead center, bottom, drivers side... Well, on the iron front diff, anyway...
If I remember right, the drain plug should be pointing at an angle towards one of the sides... I forget which...
