Steering Assembly Problem
Here's a good article on the rag joint itself:
http://jimshea.corvettefaq.com/wp-co...hing24ja07.doc
Dorman 31002 is the rag joint and you'll need some 5/16" x 1.5" long bolts, washers, and nylon lock nuts. Once you get the intermediate steering shaft out, you will have to dismantle the joint which may require a grinder.
were can you just buy the rag joint? every were i have looked you have to get the intermediate shaft along with it for 140$ i looked at flaming river and couldn't find anything.
well i found a rag joint for a 73-76 blazer... is it the same part for the 97?
luckily the local parts store had one so i went and picked it up for 13$ and 2 hours later finished putting it in. getting the old one apart was a pain but nothing that a little persuasion from the grinder didn't take care of. steering is tuns better still a little play in the gear box but i think tightening the worm gear will take care of that.
one of the parts they listed i needed replaced was $700!! dealer special i think, that must have been the intermediate shaft. plus the rag joint equaled way too much money.
also tightening the adjustment on the gear box has been bad news for alot of people
what??? yeah thats all labor. the parts are only 150$ and to replace it all you have to do is take the air box out and take out the one bolt that holds the shaft onto the gear box shaft. put the new one in and ur done. 700$ is insane
Parilio
Sep 21, 2011 06:56 AM
caseroj
Oct 20, 2010 08:10 AM
Brian J. Lesko
Dec 23, 2006 02:48 PM
