Steering wander
Old Nov 23, 2013 | 09:50 PM
T...K21's Avatar
T...K21 is on a distinguished road
Default Steering wander
Hello All,
My Blazer is starting to wander and showing excessive play in the steering. I also noticed recently with the cold weather upon us that when I attempt to steer first part of the morning it seemed hesitant making it difficult to turn.
I've replaced ball joints, idler assembly, and pitman. I haven't checked the rag joint yet. I'll check on it next time I get underneath.
Would this be the pump or steering gear?
Thanks, T
Old Nov 23, 2013 | 10:11 PM
Rags can wear and get loose. There's a steering shaft mod that includes a universal joint installation, (Jeep intermediate shaft). Pumps on these things are pretty solid. The gear box, on the other hand, likes to wear teeth on the sector shaft and it gets sloppy. Preload can be adjusted, but the gear box MUST be totally removed to properly adjust it, and adjustment is usually futile. Better off installing a remanufactured gear box.
Old Nov 24, 2013 | 10:37 PM
T...K21's Avatar
I'll have to look into that U joint conversion. I'll be already there having to take the steering gear out. Might as well right?
Old Nov 24, 2013 | 10:46 PM
T...K21's Avatar
Old Nov 25, 2013 | 03:32 PM
That would make sense, but you don't have to remove the gear box to do the steering shaft upgrade.
Old Nov 25, 2013 | 03:58 PM
newguy's Avatar
http://www.shop.synergyoffroad.com/Flaming-River-FR1746DD-Billet-Universal-Joint-S10-Blazer-ZR2-FR1746DD.htm
newguy's Avatar
Toby Hanson
13
Aug 8, 2013 03:40 PM
ck81144
Apr 22, 2012 08:24 PM
Parilio
Sep 21, 2011 06:56 AM
caseroj
Oct 20, 2010 08:10 AM
oshkosh
Suspension Tech
Nov 22, 2006 08:56 PM
