stock blazer driveshaft to s10 driveshaft
Old Jan 21, 2013 | 09:41 PM
gitch93's Avatar
gitch93 is on a distinguished road
Default stock blazer driveshaft to s10 driveshaft
hey guys i got a question i have a 2000 gmc jimmy with the stock drive sfat still. i have the rough country 2.5 inch lift with a recently added set of s10 z85 leaf pack with a extra added leaf. my problem is that it pushed my rear axle back about a inch or so and lifted it about another inch or 2 so my stock drive shaft has moved woth the lift and the slip yolk slipped out about a inch or so. im affraid that it will slip out completly and fall onto the floor. i wanna know what driveshaft i can use to fix this problem to give it back its oem fitment. if i lift the rear tires off the ground it prob will fall onto the ground
Old Jan 22, 2013 | 09:04 PM
gitch93's Avatar
can anyone help me?
Old Jan 22, 2013 | 10:05 PM
Jamaroon's Avatar
Something about this just seems wrong, I don't know what to tell you. I don't see why it would move the axle further back.
Try jacking the rear end up so the axle is at full droop, see how far out it is. You may not have a problem.
Old Jan 22, 2013 | 10:17 PM
chestypuller's Avatar
Banned
chestypuller can only hope to improve
do you have the rear springs installed in the right direction?
Old Jan 23, 2013 | 01:23 AM
Diaita's Avatar
you should be ok if its only an inch further out. My old 5" TrailMaster lift pulled my rear driveshaft out about that, and it was/is fine. I wonder the driveshaft lengths of a 2wd blazer, or a 4 door std?
Old Jan 23, 2013 | 04:51 PM
Banned
jack up rear of blazer by hitch or frame tell the rear end is hanging in the air, then see if it fall out if not then it may not unless you really droop that rear axle hard in a jump or wooptiedoo.
slowsinglecam
Jun 14, 2012 10:12 PM
Spectreblazer
Feb 13, 2010 04:59 PM
huntersblaze
Tires and Wheels
Jun 20, 2009 04:39 PM
phantom
Dec 10, 2008 04:19 PM
BLK85
Lifting Tech
Jul 12, 2007 07:50 PM
