Strange noise from front end.
Old Jul 12, 2007 | 11:51 PM
Lilcheef's Avatar
Lilcheef is an unknown quantity at this point
Default Strange noise from front end.
Afternoon folks. I have a question about my Blazer. I have a '97 and my front right wheel hums all the time when the 4WD is NOT engaged. If I push it into 4HI then the hum goes away, almost like the sprocket isn't getting pulled out all the way and the end of it is grinding the gears. If push it back to 2HI then the hum remains away but will slowly come back. This really started about 2 months ago. I was driving down the highway on a roadtrip changing the volume on the radio when I hit a bump and accidently tapped the 4LO button. Well to my understanding 4HI engages first then waits to do anything with 4LO until you go below 5MPH? There started the faint hum, however it wasn't bad. Then it just gets louder and softer randomly now so if anyone has insight I'd appreciate it. Like I also said, in 4HI there are no noises at all.
Thanks!
Chris Threlkeld
Lilcheef@gmail.com
Old Jul 13, 2007 | 01:14 PM
DCFluX's Avatar
DCFluX is an unknown quantity at this point
Default RE: Strange noise from front end.
I would suspect your CV joints are going bad. These connect the half-shafts to the transfer case to give power to the front wheels. Placing the drive in 4HI would put torque on the joints instead of leaving them loose to wabble which would explain why you only have noise in 2WD. Also you might get a clicking noise when you make a hard turn like a front wheel drive car would do when the joints go bad.
The Blazer will not go into 4LO until the car is in neutral and between 0-3 MPH.
Old Jul 13, 2007 | 08:14 PM
Lilcheef's Avatar
Yeah I was fearing that. How hard are the CV joints to replace on these trucks?
JasonGoneFishing
Jun 5, 2014 09:56 PM
Joseph Rangel
Feb 4, 2013 09:15 PM
Chrismacster
Apr 2, 2009 06:57 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
Fenris
Sep 12, 2008 01:37 PM
