stuck in 4w drive
Old Aug 26, 2013 | 06:25 AM
Scarakus's Avatar
Scarakus is on a distinguished road
Default stuck in 4w drive
i got a 97, shifts ok between 4lo & 4hi, but not back to 2wd. can hear shifting sounds up front when i press the 2wd, but stays lock in 4hi, light stays on for 4hi as well.
any quick suggestions...?
Old Aug 26, 2013 | 07:34 AM
Timbl's Avatar
Timbl is on a distinguished road
there is a transfer case vacuum switch on the center firewall which is common. check vacuum lines to it. I had the same problem and I replaced the switch on the dash and it solved it. these are two relative easy areas to start.
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
huskerinaz
Jan 19, 2008 10:53 AM
dcblazer
Dec 18, 2006 06:07 AM
