suspension lift kit
Old Jan 16, 2011 | 09:17 PM
des plaines blazer's Avatar
des plaines blazer is on a distinguished road
Smile suspension lift kit
i just finished the front end part of the lift kit rough country 3 inch the upper control arms bushings are to gapped between bushing and frame brace as for the torsion keys replacement you really need to be careful of tension i dropped lower cont arm and disconected sway bar which was holding me up to drop the keys from torsion crossmember you also need oxy actelean to get porkchop cherry hot and use chisel and sledge to release from crossmember the lift kit supplied new porkchop but what a BS the instructions missed out which i found out how to remove keys due to this web site im stil working on drivers side i also found out what makes noises when turning right the TORRSION CROSSMEMBER BUSHINGS WHICH I THOUGHT WERE CVS
Jkrumm
Lifting Tech
Feb 17, 2011 04:35 PM
ericthughes
Lifting Tech
Oct 13, 2010 10:56 PM
COUNTRYBOY061488
Aug 28, 2008 07:54 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
