swapping stock for zr2 front and rear axels?
Old Jan 31, 2012 | 12:59 AM
N3ROST4R's Avatar
N3ROST4R is on a distinguished road
Default swapping stock for zr2 front and rear axels?
There is a guy on craigslist parting out his zr2 and I was considering seeing if he still has the front and rear axels. I currently have a 95 s10 blazer ls and I have a 2'' body lift and am running 31" tires. I have noticed a slight power loss and definetly a hit to my mpg. Will swapping out the axels and changing to the zr2's gearing help enough with the mpg and power loss to make it worth while? If so how much should I be looking to spend? I have searched about gearing but I haven't really found a definitive answer. Thanks guys.
Old Jan 31, 2012 | 01:03 AM
Thogert's Avatar
It really depends on what gears you have in your blazer now.
Old Jan 31, 2012 | 01:08 AM
NVANZEE's Avatar
yeah you could have 3.73 gears in your stock rear end. So then there would be no point in putting the time and money into swapping them. It also wont be real cheap unless the guy hasnt checked on prices at junk yards. I paid 450 for just the rear axle out of a ZR2. On top of that i had to replace all the bearings and seals.
Old Jan 31, 2012 | 01:20 AM
N3ROST4R's Avatar
How do I check what gearing I have?
If its gonna cost that much I would probably be better off making other upgrades to counter act my losses. hmm..
Old Jan 31, 2012 | 12:48 PM
Thogert's Avatar
Check the RPO code in your glove box. It should say GU6 or something like that, sorry I can't remember all of the codes. (Not G80 though, that's a different story.)
Old Jan 31, 2012 | 03:43 PM
neo71665's Avatar
Zr2 rear axle is 2inches wider. The front diff is the same you have now unless the zr2 is one of the rare iron diffs.
GU2 2:73 ratio
GU4 3:08 ratio
GU5 3:23 ratio
GU6 3:42 ratio
GT4 3:73 ratio
GT5 4:10 ratio
GQ1 Open Differential Rear Axle
G80 Positraction/Locking Rear Axle
Old Jan 31, 2012 | 04:13 PM
N3ROST4R's Avatar
Okay I do have 3:73 so that would be a waste of time. Lol. Thanks guys for the help.
Old Feb 1, 2012 | 09:58 AM
mike mtzr2's Avatar
mike mtzr2 is on a distinguished road
where/ city on craigs list? thanks.
Old Feb 1, 2012 | 12:42 PM
N3ROST4R's Avatar
Milwaukee Wisconsin
14144265483 that's the phone number he listed
Old Jun 26, 2012 | 06:43 PM
BlaziNator's Avatar
BlaziNator is on a distinguished road
I have 3:42 gears in mine. Worth swapping? I get about 17 MPG at 70. 18.5 at 60-65. What MPG do stock ZR2's get anyhow?
