sway bar
Old May 10, 2009 | 12:20 AM
hockeydude55's Avatar
hockeydude55 is on a distinguished road
Default sway bar
I just looked at my front left sway bar and was shocked that i had no bushings or bolt on it. It was just there unattached. My car is not driving any different and is not even noticeable on the highway. How much are bushings and bolt, and where is the best place to get them from. Also how hard are they to put in, it seems simple enough.
98 s10 4dr 4wd lt
Old May 10, 2009 | 02:36 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
im not quite sure how difficult itll be ive never done mine, but i would strongly suggest useing polyurathane (sp?) bushings theyll give you much improved handling and they tend not to degrade over time like rubber bushings will. im not sure how much front sway bar bushings are, but check out sites like stylintrucks i know they carry them.
Old May 10, 2009 | 03:47 AM
02 jimmy's Avatar
02 jimmy is on a distinguished road
I just finished replacing mine, it's a very easy job to do, hardest part is taking of the old ones off, but thats done already for you. For both sides it cost me 15 bucks for the bolt and bushings
Old May 10, 2009 | 12:29 PM
Swain's Avatar
Swain is an unknown quantity at this point
It will be under $20 for both sides. First take off the passenger side then put the new ones both in place before you tighten either down. This will make it easier then doing one side at a time then you would need leverage on the sway bar to get the second bolt in. Ask me how I know
Old May 10, 2009 | 01:34 PM
Yes, very easy and very inexpensive.
Old May 10, 2009 | 04:18 PM
Yup i just finished doing it now. The hardest part was getting the old one off had to saw through it. Thanks for the help guys
Old Jul 5, 2009 | 11:51 AM
Blazermax's Avatar
Blazermax is on a distinguished road
I've got a '93 full size blazer 4WD and bought replacement Moog links. I finally got the old rusted ones out, but I can't get the long bolts to pass through the sway bar holes and then through the body frame.
Do I need to take the sway bar out first? Or do I need to jack the vehicle first? Will I then need to somehow compress the sway bar?
Thanks in advance.
1993 Blazer 4WD with Sports Package
pj5454302
Lifting Tech
Jan 21, 2010 08:19 AM
jaybird33081
Jan 4, 2010 03:12 AM
powwowblazer
Suspension Tech
Jun 26, 2006 05:22 PM
cherryred4x4
Suspension Tech
Apr 4, 2006 08:05 PM
timetoblaze
Suspension Tech
Oct 30, 2005 12:17 PM
