!!Sway Bar HELP!!
Old May 1, 2012 | 04:24 PM
LilPudge666's Avatar
LilPudge666 is on a distinguished road
Question !!Sway Bar HELP!!
ok well guys my sway bar bushing is shot and i got the new bushings i never worked on sway bars before, how do i replace the bushings? do i take the stabilizer bars out and drop the sway bar or just pop the new bushings on?
Old May 1, 2012 | 10:43 PM
Rottidog's Avatar
Don't know what vehicle you're talking about, front or rear sway bar, year etc.
You shouldn't have to remove the sway bar, possibly just loosen the bolts on the bracket that holds it so it can rotate easier.
But basically you only have to soak the bolts/nuts in PB Blaster or whatever kind you use, undo the bolts paying attention to how they're situated on the bolt (what bushing, where in order - take a pic to refer to), clean the threads with a wire brush, slop some antiseize on the threads & reasemble them. I'm not sure of the torque on them though.
Old May 1, 2012 | 10:48 PM
Thogert's Avatar
You may find that the top 'bolt' is actually just a washer with threads on it so you might need to get a pair of nuts (giggity) that will fit on the studs.
Old May 1, 2012 | 11:25 PM
Rottidog's Avatar
Yup true enough, that bolt (if it's the front sway bar) has that threaded washer on top (I know a 2002 2nd gen has them). A pair of slip joint or vice grip pliers will get ahold of it.
Old May 2, 2012 | 08:00 AM
my 2000 chevy blazer front sway bar
Old May 2, 2012 | 08:04 AM
yep its a threaded washer, its the bushing on the driver side I got this truck used and there the orignal chevy (GM) made bushings and any ideas on moog bushings?
Old May 2, 2012 | 08:49 AM
rexmburns's Avatar
Super Moderator
Moog makes a good product from my experience. I know that Advance also has these bushings and from what I have read they are a top quality brand as well and at least the ones near me keep them in stock. As soon as I finsh this post I am going to go buy them myself.
Old May 3, 2012 | 09:52 PM
volcer's Avatar
volcer is on a distinguished road
hello i have 2002 blazer and the sway bar bushing brackets has been lost the bolts have been lost .. is there any where you can purchase the bolts is there a product number? or a website you can get this part thanks
Old May 3, 2012 | 10:28 PM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
Old May 3, 2012 | 11:00 PM
Rottidog's Avatar
Spending some time searching in here & google or whatever you prefer does help. Just takes a bit of time & maybe a few bevies.
