sway bar removal
Old Feb 12, 2010 | 08:38 PM
mxboy96's Avatar
mxboy96 is on a distinguished road
Default sway bar removal
I've got a 97 S10 blaze, 4x4 with the 4.3. I'm considering removing the front and rear swaybar to get better suspension performance and travel. I use it off-road more than I do on road. I just want to know your opinion/ suggestion on this. Weather it would be ok or have a negative effect in the long run. My thinking is it will allow the suspension to move freely of each side except for the rear cause it's a straight axel. Any input is welcome. Thanks!
Last edited by mxboy96; Feb 14, 2010 at 09:02 AM. Reason: So I tried taking them both off...helped out the suspension 150% if not better. But yea, 'holy bodyroll batman!',lol.
Old Feb 12, 2010 | 09:50 PM
AJBert's Avatar
It does wonders offroad for more articulation up front, not so much in the back. Keep in mind, with more articulation comes more wear and tear on front end components, but the trade off is worth it, IMHO, for keeping all four tires on the ground where they tend do to better than being in the air.
You might want to look at making your front sway bar able to be quick disconnect rather than removing it. Pretty easy to do.
On road, you'll notice a bit more body roll but nothing that isn't manageable, providing you don't drive like a teenager.
Old Feb 13, 2010 | 08:57 AM
pj5454302's Avatar
I removed my rear swaybar and I cant even notice its gone. I took the front sway bar off when i removed the rear and all i can cay is holy bodyroll battman! So i made my front disconnectable.
Old Feb 23, 2010 | 12:20 PM
chrisf719's Avatar
chrisf719 is on a distinguished road
Default Quick Disconect
How are you guys making the front sway bar a quick disconnect. Just curious Thanks
Old Feb 23, 2010 | 12:39 PM
ABN31B's Avatar
replacing the threaded metal garbage/nut at the top of the link with a wing nut. drill a little holt in the bolt and drop a cotter pin in it so the wing nut doesn't walk off when you are on the street.
search it up, i believe there is a how to floaing around here or at least a link to where it does live (s10 forum i believe)
bdemutis
Apr 3, 2013 12:27 PM
jackdough
Aug 28, 2010 06:33 PM
fondo
May 17, 2010 03:13 PM
jdespain
Lifting Tech
Mar 11, 2010 11:47 PM
Yooper
Nov 6, 2009 07:26 PM
