Tire scrubbing sway bar
Old Apr 18, 2007 | 11:38 PM
jjay74's Avatar
jjay74 is an unknown quantity at this point
Default Tire scrubbing sway bar
Hello, all. I found this forum tonight and have already found a lot of useful information here. I signed on to inquire about the front end "popping" noise and have found a lot of things to check. I have an additional and possibly related problem.
On the driver's side front, there is a shiny spot on the sway bar where the tire has been rubbing. Is this normal? Is this possibly a result of ball-joints, tie-rods, etc. needing replacing? I have a strong feeling that these problems are related.
Any help will be greatly appreciated.
2003 S-10 Blazer, 2wd, 4 door
Old Apr 19, 2007 | 12:07 PM
aris_unlimited's Avatar
aris_unlimited is an unknown quantity at this point
Default RE: Tire scrubbing sway bar
I am assuming that you have checked all the bushings in the front suspension ie. sway bar, torsion bar, control arm etc etc. I havea 2000 blazer 4wd so these should be some what similar. If you get the front end up in the air there is a metal buffer pad that should hit the wheel before the wheel is able to get to the sway bar, so I would check to see if that is there. It is not very big so it might be kind of hard to find at first, just check the back of your wheel and see if there is any scraping near to the inside of the wheel. Also just a question, have you done any suspension mods? How is your alignment?
Old Apr 22, 2007 | 02:44 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
I have a shiny spot there too, but my tire deosn't get close to it...
pj5454302
Lifting Tech
Jan 21, 2010 08:19 AM
jaybird33081
Jan 4, 2010 03:12 AM
powwowblazer
Suspension Tech
Jun 26, 2006 05:22 PM
cherryred4x4
Suspension Tech
Apr 4, 2006 08:05 PM
timetoblaze
Suspension Tech
Oct 30, 2005 12:17 PM
