Towing a Heavy Load
Old Jun 11, 2019 | 07:36 AM
Thuwaldt's Avatar
Thuwaldt is on a distinguished road
Default Towing a Heavy Load
Hello all! I just bought a boat, and with a full tank of gas, trailer and boat are probably weighing in around 4000lbs. My '97 S10 Blazer LS is rated to pull a load of 5000lbs, so in theory, I should be ok. However, I have around 210,000 miles and am a little worried about this larger load on my old Blazer. Does anyone have any experience, or stories to tell? Do you think the truck will be ok with that load? What are some considerations when it comes to highway driving, or hillier roads?
Also, what are some things that I should keep an eye on? Are there any immediate things that you would service/inspect/upgrade to prevent any mechanical failures?
Thanks as always to any thoughts on the matter!
Old Jun 11, 2019 | 07:45 AM
cleburne red's Avatar
Be sure to not tow in overdrive, I've heard that's hard on the transmission.
Other than making sure the truck is mechanically sound, goos tires, etc, you should be good.
Depending on tongue weight, might look into weight distribution hitches, or maybe stronger leafs/air shocks for the rear
Old Jun 11, 2019 | 12:19 PM
You might also want to add an external transmission cooler, if you don't already have one.
Old Jun 11, 2019 | 03:26 PM
Ditto to the comments above.
I burned up my 3/4 clutch pack and had to have my transmission rebuilt because I was towing using overdrive. I also tow up and down some pretty big grades.
When I had it rebuilt I had an extra external cooler installed for the transmission fluid. I also purchased a OBD gauge (Ultragauge) that allows me to also monitor the temperature of the transmission fluid. Our transmissions have this capability but no gauge on the cluster.
I tow a trailer/boat that weighs 2,200 lbs. For you I'd also make sure the trailer brakes work. If you don't already have brakes on the trailer you should at that weight.
Check the specs for the weight that can go at your hitch and make sure the tongue weight is not more than that value. For a 5,000 lb trailer I think the tongue weight could be about 500-650 lbs. At that tongue weight, some helper springs might be in order.
Old Jun 12, 2019 | 07:53 AM
Thuwaldt's Avatar
Good stuff. I just ordered fresh shackles for the leaf springs. Anything else that might be under additional stress? Anything in particular that I could do to the brakes to increase their durability?
Old Jun 12, 2019 | 07:54 AM
Thuwaldt's Avatar
Good call. Just ordered one. Cheap and easy insurance.
Old Jun 12, 2019 | 07:56 AM
Thuwaldt's Avatar
Wait, so you're saying that there is actually a sensor that reads trans temp that can be picked up using an OBD2 tool/gauge? The trailer does NOT have brakes...
Old Jun 12, 2019 | 11:50 AM
First I've heard of that. That would be pretty cool. I've been planning to install a trans temp guage, be nice if there was a factory sensor to tap into
Old Jun 12, 2019 | 12:38 PM
Yep! Pretty cool, isn't it?
There is at least one more OBD-II gauge reader that can access that information that I know of but this is the one I got (see below). I liked the price and the form-factor for the readout.
The minimum number of readouts is four. The data I have it display for me are; Engine Coolant, Transmission Fluid Coolant, Corrected MPH (I have larger tires on mine) and the MAP sensor (purely for curiosity). You can also set alarms for all values.
If you are really nerdy, you can have to scroll through many pages of data and have more data per page. It also has the ability to read and clear the OBD-II codes that would display the "Check Engine Light". So it is only a basic code reader as far as that goes.
I've been pretty happy with it.
I mounted mine on top of the cover for the transmission hump that holds the remote cassette player.
UltraGauge OBDII Scan tool & Information Center
Old Jun 12, 2019 | 12:44 PM
Oh and regarding trailer brakes; for me I'd be weary of towing anything that weighed much more than what I tow (2,200 lbs) if it did not have its own brakes. That is a lot to stop.
And regarding brakes for the truck, I've been waiting for an excuse to upgrade my brakes. The ones by Power Stop are currently at the top of my list.
https://www.powerstop.com/product/po...%20Rear&ss=4WD
