Transfer case
Old Oct 6, 2012 | 10:45 AM
Nate1980's Avatar
Nate1980 is an unknown quantity at this point
Default Transfer case
Since I bought my Blazer one year ago the only preventive maintenance I have not done is changing the fluids in both differentials and the transfer case. Yesterday I changed the gear oil in both differentials. Chose to use mobil 1 LS 75w-90 in them. Then when I got to the transfer case. It said to use dexron III or auto-trak II. Which one? Where do I get it? According to my Haynes manual there is 3 choices in transfer cases, 133/136, 233, or a 236/246. All have different fluid capacities, how do a tell what type I have?
Old Oct 6, 2012 | 11:43 AM
50lb_cat's Avatar
If you have the 4 button then it takes the auto trak 2, very expensive stuff. If its the 3 button then just dexron 3.
Old Oct 6, 2012 | 12:01 PM
Nate1980's Avatar
So I have four button. 2hi,4lo,4 hi, and auto four wheel drive button. When I changed front diff oil, I noticed it was leaking.so I cleaned the underside of blazer spotless. I seen that it has a small leak where the driver side cv axle mates to it and also the seal is leaking where the shaft from transfer case enters the front diff. Even though they are not bad leaks, I'm going to have to fix them. Anybody else discover this nightmare on there vehicle ?
Old Oct 6, 2012 | 12:16 PM
50lb_cat's Avatar
I've replaced those seals on my jimmy and my father in laws blazer. They seem to be pretty common. Its not too bad of a job, just take your time. Be prepared for some sticker shock on the auto trac fluid, last time I looked it was almost 30 bucks a quart.
Old Oct 17, 2012 | 11:24 PM
BudsterXT's Avatar
BudsterXT is on a distinguished road
The Auto Trak fluid is like 8.95 a qt (litre) actually at the dealership.
Or got to summit here is a link http://www.summitracing.com/parts/NAL-88900402/
Old Oct 17, 2012 | 11:28 PM
BudsterXT's Avatar
The fluid at summit is GM. After shipping you only save a couple bucks.
If you live a ways from a GM dealership it is a viable option.
I got three 33.8 oz bottles for under 28.00 including shipping
Last edited by BudsterXT; Oct 17, 2012 at 11:31 PM. Reason: adding more text hit wrong button
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
bob2231
Nov 6, 2005 04:40 PM
loscochinos520
May 28, 2005 11:32 PM
buckwheat
Jan 6, 2005 04:59 PM
