Transfer case drop
Old Nov 8, 2019 | 09:01 AM
03jawja's Avatar
Default Transfer case drop
Does anybody know what I would need to get some gap in between transfer case just to help with cv axle angle, when I add lift soon?
Old Nov 8, 2019 | 11:55 AM
Are you talking about the transfer case or the front axle?
Old Nov 8, 2019 | 12:07 PM
03jawja's Avatar
The transfer case itself...I know that the rough country lift has spacers or some type of bracket to help with axle angle
Old Nov 8, 2019 | 04:44 PM
Theres a drop bracket, and a small wedge space for the other side. I dont have any pics at hand, but mind be able to get a glimpse of it on my build thread.
Old Nov 8, 2019 | 08:30 PM
Here's a picture of the wedge installed on the passenger side
Old Nov 8, 2019 | 09:59 PM
I think you're confusing the transfercase with the front differential...
The transfercase is bolted to the back of the transmission and has the front and rear drive shafts coming out of it, going to the front and rear differentials. You can't move the transfercase down without moving the entire engine and transmission down along with it.
The front differential is where the front axles are bolted to fro the front left and right wheels. The differential (or carrier as it's commonly referred to) is what you want to space away from the frame and drop down with a lift to achieve better CV axle angles.
Old Nov 9, 2019 | 08:57 AM
03jawja's Avatar
Yes exactly I meant front differential. Could this bracket be made cheap. Could I just use spacers and longer bolts?
Old Nov 9, 2019 | 01:16 PM
Stock bolts work, and dont see why you cant make it, just an aluminum wedge. Not sure on measurements...
Old Nov 9, 2019 | 08:04 PM
Hess13x's Avatar
Found this on eBay. Cheaper and easier than trying to build it I would think.
https://www.ebay.com/itm/82-05-GMC-S...-/133031355876
Old Nov 11, 2019 | 08:52 AM
03jawja's Avatar
Thank you Hess I'm on it
