transfer case motor , seriously i am about to flip out !
Old Apr 7, 2010 | 09:22 PM
thebigjimmy's Avatar
thebigjimmy is an unknown quantity at this point
Default transfer case motor , seriously i am about to flip out !
my 98 jimmy (np1 , 3 button) would always go into 4wd fine but sometimes it was stubborn about going back into 2wd . there were no codes and everything else looked / tested fine so i always assumed it was the TCEM because you could hear the motor try put the case back into 2hi .
today i go and buy a reman TCEM and install it . when i pushed the 4hi button i could hear the relay in the dash click but got nothing from the TCEM not even a sound , uninstalled and reinstalled 3x , same thing.
i thought maybe i got a bunk reman so i exchanged it for another , install it . SAME THING .
Now i returned the reman motor and got my original 1 back and still nothing will work ..
so now i have nothing , before i at least had a 90% working 4x4 now 2 motors , few hrs of work and i have a 0% working 4x4 .
i have gone over the plug and wires near the motor and it all looks good.
before doing this i got no codes , now i get code 3 & 4 . what did i screw up ? i did nothing but unplug the motor , remove the 3 bolts and install 2 new motors and now the original ..
Old Apr 7, 2010 | 10:16 PM
old skool luvr's Avatar
Originally Posted by thebigjimmy
please help before i figure out a way to run myself over with my own truck .
that's actually not that hard-running yourself over with your own truck, i mean.
as for your non-functioning 4WD, have you checked the switch yet? how about the wiring? since this became 0% working after you touched the TCCM, start inspecting the plug harness there for any loose or damaged wires.
also do the same @ the encoder motor. you may have had some damage down there from something getting kicked up.
Old Apr 8, 2010 | 02:39 PM
as soon as the weather cooperates (figures it had to rain today) i am going to check the wire harness , that is really the only thing that has been touched .
if that does not work i was considering removing the windshield so i can do a running dive off of the hood while driving ..
Old Apr 8, 2010 | 06:50 PM
Drifter666's Avatar
Drifter666 is an unknown quantity at this point
honestly dude, chill out. It no use being so dramatic it wont fix your problem any faster. Go to a junk yard and grab a switch most of the time you can just pocket it. If there is nothing wrong with the wires try the TCCM fuse maybe it popped while installing something.
Old Apr 10, 2010 | 09:24 PM
updated the original post ...
LesMyer
38
Jan 9, 2020 11:45 AM
Flyfishen
Jun 18, 2019 11:22 AM
95blazerlt
Jan 16, 2010 12:44 AM
blazerwithballs8
Apr 2, 2009 06:54 AM
Jharper
Nov 29, 2007 09:43 PM
