transfer case question
No, the transmission and transfer case do not share fluid. As far as checking the fluid level, the s-series trucks have two plugs on the back of the transfer cases. The lower one is the drain plug while the upper one is the fill/level plug. Remove the upper plug and the fluid level should be even with the bottom of this hole.
If you want more specific information, you will need to post your vehicle information. In the future, please provide this information in each post where you are asking for technical advice/information. Consider putting it in your signature and setting the option in your control panel to attach your signature to all of your posts automatically.
in my 2000 zr2 blazer i need to change my front diff fluid and t/case fluid.. What and how much of each should i use.
2000 4wd Zr2 Blazer
my push button 4x4 has a 2hi, 4hi and 4 low button, if that helps or matters.
thanks,
ty
2000 4wd Zr2 Blazer
thanks,
ty
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
kmartin
14
Dec 3, 2008 12:48 PM
doodad69
Nov 29, 2008 03:25 PM
Screamin
Sep 12, 2007 09:53 AM
