Trouble with Transfer Case ??
Old Mar 30, 2010 | 03:41 PM
Black fluid is not a good sign. That means that it has gotten quite hot. I don't believe that Autotrak 2 smells any different when it is degraded than the new stuff. Never has in any of the tc services I have done and that did include some that I had to tear down to find out that the clutch pack was toast.
Old Mar 30, 2010 | 05:06 PM
Don Green's Avatar
Don Green is on a distinguished road
By smelled the same I meant it didn't smell burnt. Tomorrow will tell, I'll top it up all the way and test drive it. Wonder if the old oil which I imagine is the orginal fluid degraded enough to cause the clutches to just slip?
Old Mar 31, 2010 | 05:12 PM
Don Green's Avatar
Topped up the fluid, no go on the ground. Guess the clutches are pooched. No need to remove the torsion bar cross member to remove the transfer case is there?
Old Mar 31, 2010 | 05:23 PM
You should not need to remove the torsion bar cross member.
Old Apr 16, 2010 | 06:32 PM
Don Green's Avatar
Here's the update on the problem. The clutch pack was screwed. Had the clutches replaced. Also had a GM encoder motor as the new aftermarket one wasn't putting enough pressure on the shift fork I'm told.
Old Apr 16, 2010 | 07:04 PM
Damn. That sucks. At least you got it fixed. I'm curious how much that set you back.
Old Apr 16, 2010 | 07:44 PM
Don Green's Avatar
$450 can for the transfer case service and $350 for the Reman GM encoder motor. I provided the oil, they cleaned put new seals in the T case too.
Old Apr 16, 2010 | 07:51 PM
$450 for the clutch replacement isn't bad. Those clutches are $$.
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
jmonty0523
Feb 26, 2013 09:59 AM
dudevoit
Mar 8, 2011 06:14 PM
thenours
Mar 17, 2009 09:00 PM
