Universal joint removal 97'
Old Sep 27, 2008 | 11:11 AM
gmbwrenchn's Avatar
gmbwrenchn is an unknown quantity at this point
Default Universal joint removal 97'
97' Blazer 4X4 145K Miles. How do you remove the u-joints from the main drive shaft? Are they pinned in some how?Looks like there is plastic pins in the front one and plastic pin and bolted in the rear. Have play in the rear one and want to replace both right away. Thanks.
Old Sep 27, 2008 | 11:24 AM
midnightride_69's Avatar
midnightride_69 is an unknown quantity at this point
Default RE: Universal joint removal 97'
You have to heat them up with a torch and melt theplastic out of them. It will squirt out like a worm.
Old Sep 27, 2008 | 11:26 AM
Have a read through the first few threads in THIS SEARCH. Post up if you still have questions.
Old Sep 27, 2008 | 08:10 PM
gmbwrenchn's Avatar
Thanks for that info. So......I think I will just replace the rear U-joint. That has the play in it.Just remove the 4 bolts, heat up the u-joint until the plastic oozz's out, then pop the u-joint off the yoke with a pry bar, and the same for thedrive shaft end, correct?I don't have to remove the drive shaft do I? Also, I don't need to use a press to getthe new one on do I? Should be able to tap it on?And also, I want to get a u-joint from Advance auto.com, they have mutiple different ones, 1.188,1.125 bearing O.D.,as well as different bolt lengths to use with the u-joint, .75, 1.31. What should I be looking for. Thanks for the help.
Old Sep 27, 2008 | 11:06 PM
bad350v8s10tahoe's Avatar
bad350v8s10tahoe is an unknown quantity at this point
The new one will tap in, you dont need a press. Get the napa off road u-joint or spicer heavy duty, dont buy advance orautozone crap
Old Sep 28, 2008 | 10:26 AM
gmbwrenchn's Avatar
Thanks again
Old Oct 9, 2008 | 08:34 PM
gmbwrenchn's Avatar
Will a regular propane torch get hot enough to melt the plastic out?
Also, should I remove the drive shaft or can I leave it in? Thanks.
Old Oct 9, 2008 | 08:37 PM
You will be there for awhile, but it should bring the temp up enough to flow the nylon.
Old Jul 17, 2009 | 08:24 AM
97blazer617's Avatar
97blazer617 is on a distinguished road
hey...did you end up replacing the u-joint. how was it...asking because i might have to change it..thanks
josemateos
Feb 18, 2014 10:00 AM
Guntheone
Dec 4, 2010 05:59 PM
gabhanjacisa
Dec 1, 2010 08:33 AM
jrad0425
Feb 22, 2010 09:27 PM
Canadian88
Jun 25, 2006 04:33 PM
