vacuum actuator
Old Feb 7, 2010 | 06:36 PM
515Blazer's Avatar
515Blazer is on a distinguished road
Default vacuum actuator
when ever my engine is running my front axle is always locked in, when i shut the engine down it takes about 15 mins for the vacuum to bleed off and the actuator disengages and i can spin the front drive shaft like normal. what could cause this and will it cause me any problems when i put the truck on the road. and it didnt always do this, it just started out of the blue one day
Old Feb 7, 2010 | 07:07 PM
What 4wd system do you have; 3-button switch or 4-button switch on the dash?
If 3-button, it could be a faulty switch on the transfer case or it could be improperly routed vacuum lines.
If 4-button, it could be a failed vacuum solenoid on the firewall or (again) improperly routed vacuum lines.
Old Feb 7, 2010 | 07:15 PM
515Blazer's Avatar
i have the 3 button system (98 4dr LS), when i bought it had a fualty TCCM. i replaced that and everything worked fine. i was playing around with it shifting in and out of 2hi, 4hi , and 4lo. i had chacked everything over several times and one time i crawled under and the drive shaft would not turn in 2wd. i jack up a front tire and relised the vacuum actuator was still engaged. its been like that ever sence, i think the vacuum switch on the tcase is stuck in 4wd posison.
i never touched the vacuum lines, it worked and now it dont work right idk why exaclty
Last edited by swartlkk; Feb 7, 2010 at 07:27 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT function to add additional information to your post if another member has yet to reply.
Old Feb 7, 2010 | 07:27 PM
Sounds like the vacuum switch has failed in the open position. If the lines are proper, that is the only thing that could cause your symptoms.
Old Feb 7, 2010 | 07:30 PM
515Blazer's Avatar
well i can still use 4wd and 2wd just fine, i was mainly concerned if this will give me any problems down the road
Old Feb 7, 2010 | 07:34 PM
If the front axle is fully engaged, you shouldn't have any problems other than a decrease in fuel mileage.
Old Feb 7, 2010 | 07:41 PM
515Blazer's Avatar
how much of a decease are we talkin 1mpg every bit counts
Old Feb 8, 2010 | 08:34 PM
notrealimportant's Avatar
notrealimportant is on a distinguished road
what is that switch called and is it a dealer item only? I assume we are talking about the one on the front axle?
Old Feb 8, 2010 | 09:20 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
The vacuum switch is located on top of the left side of the T-case. When the fork moves forward when you put it in 4 wheel drive it opens up to port vacuum to the front drive axle actuator. I'll stop there. Every time I think about how the 4X4 system works in these things it just drives me up the wall. Can anyone say "Rube Goldburg"? Can't actually believe someone would put a system like that in a production vehicle. But don't get me wrong. I love these damn things.
markrd
May 8, 2009 01:39 PM
toofancy83
Dec 11, 2008 11:23 AM
TheJuicer
Oct 16, 2008 10:59 PM
watsonracingteam
Aug 25, 2008 04:48 PM
rooster
Feb 18, 2007 07:16 PM
