Vibrate & humming
Old Oct 16, 2015 | 07:52 AM
Lucigrl's Avatar
Lucigrl is on a distinguished road
Default Vibrate & humming
I just installed new hubs in the front. Now I am noticing a hum/whine and a little vibration thru the gas pedal. I thought I may have gotten a bad hub so I replaced the new set and no change. It gets more noticeable the faster I go. It does sound like a bearing noise. I have no clicking sounds on turns so I am ruling out CV axles. This is for sure coming from upfront somewhere. Any ideas? 2004 LS Blazer 4x4
Luci
Old Oct 16, 2015 | 08:23 AM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Have you had the front end aligned after replacing the hubs?
Old Oct 17, 2015 | 06:29 AM
Lucigrl's Avatar
Why would I do that? Nothing in the alignment is disturbed with hubs.
Old Oct 17, 2015 | 07:43 AM
CWBDDSPC's Avatar
Because you have a vibration in your front end...
I'd have them balance the wheels too.
If you are lucky, they will be able to do the alignment. If you are not, they are going to tell you what other components in your front end are failing.
The front section of the factory service manual runs through multiple causes of vibrations
JohnBarJB
Sep 28, 2020 07:34 PM
tommychet
Dec 24, 2006 03:31 PM
hoppy2
Suspension Tech
Nov 17, 2006 03:31 PM
blazinloud
Engine & Internal
Sep 10, 2006 07:01 PM
2drblaze
Jun 22, 2006 08:11 PM
