Vibration 02 S10
Old Dec 21, 2021 | 05:45 AM
S106802's Avatar
S106802 is on a distinguished road
Default Vibration 02 S10
I have a 02 4 wheel drive extended cab 3 door S10. I just recently bought an installed rough country two and a half inch lift, before I put my new tires on I had a vibration, my tires were cupped and in bad shape. So I was hoping it was just the tires. Got my new tires installed and have the exact same vibration it was right about at 70 miles an hour, I noticed the pinion angle had changed a little more than I thought it would so I bought some 4° shims and install them. The vibration is different now but still there now it starts about 60mph below those speeds the truck drives flawless. Before I lifted the truck it drove perfectly smooth so I'm guessing it's the angle of the pinion or u joint ?
Old Dec 21, 2021 | 08:20 AM
Your pinion angle is "backwards". The pinion should be pointing down slightly in relation to the driveshaft, not up. Ideally, the angle at the back of the transfer case would match the angle at the pinion yoke, but within a degree or two should work ok.
Here's all the information you could ever want, plus some.
MArseyus
Jan 6, 2013 12:09 PM
GaryF2012
Dec 28, 2011 05:27 PM
bobtrub
15
May 6, 2010 08:51 PM
Scooterewski
Jun 2, 2008 09:21 PM
ksibley603
Jan 9, 2008 10:11 PM
