WANNA CLEAR 285-60-18S?????????????
Old Nov 13, 2007 | 05:07 PM
blackblaze99's Avatar
blackblaze99 is an unknown quantity at this point
Default WANNA CLEAR 285-60-18S?????????????
WANNA CLEAR 285-60-18S ITS ABOUT 31.46 TALL,& 11.22 WIDE,,I HAVEA 99 S10 4DR BLAZER 4WD,,,I SEE ALL THESE KEY AN SHACKLE KITS ?? IS IT GONNA RUIN THE RIDE AN IF NOT WILL IT HAVE ALINMENT ISSUES CUZ I DONT WANNA CHEW UP THESE TIRES DUE TO NOT BEING ABLE TO GET THE RIGHT CAMBER? IVE SEE SUM OFFER 2" KITS WITH CONTROL ARMS ARE THOSE NECCASARY,,I DONT FOUR WHEEL IT MAYBE JUST SUM ROUGH ROADS AN SNOW IN THE WINTER ,,,NEED INFO???HOPE FULLY SOMEONE HERE HAS TRYED THESE PRODUCTS AN CAN GIVE ME SUM INFO??????THANKS
Old Nov 13, 2007 | 05:11 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: WANNA CLEAR 285-60-18S?????????????
Please do not post in ALL CAPS..... Anyway. If I were you I would check into a body lift.with that you will have no alignment issues.
Old Nov 13, 2007 | 06:19 PM
WolfPack's Avatar
maddox said it best...
[IMG]local://upfiles/8486/F6DF9C1C1BF543B5BF79F61E3E98D3E3.jpg[/IMG]
Old Nov 13, 2007 | 06:24 PM
i ve got it with the caps lock,,,thing rushin leavin work just wanted info,,,i think i got that down not that ive gotten 2 post about caps lock
Old Nov 13, 2007 | 08:08 PM
drperry's Avatar
A body lift and a bit of a tortion bar crank should clear them.. do some searching around here, I'm pretty sure there's a thread or two that covers it...
The tortion key things just make it so you can adjust them even MORE than the factory setup... You're still working everything at nasty angles...
If you only have to lift a little bit, you won't wear out anything any faster, especially since you don't off-road...
streetbob07
Tires and Wheels
Aug 2, 2013 04:07 PM
Jaymoung
Jan 16, 2011 09:07 PM
Bravado
Tires and Wheels
May 16, 2009 11:16 PM
fla_blazer4x4
Tires and Wheels
Mar 22, 2008 10:06 AM
Sean Pedro
Tires and Wheels
Apr 1, 2007 06:53 PM
