wheel alignment done, does not ride as good
Old Oct 1, 2011 | 11:16 AM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
Default wheel alignment done, does not ride as good
2000 4x4 4dr blazer, with sagging "premium" suspension
I replaced right side inner tie rod and the idler arm all moog parts.
Last year replaced all ball joints with moog, and shocks forgot wut brand but lifetime warranty did this 10k ago.
After I pulled the steering shaft to get to the spark plug my wheel was never straight, and started pulling to the left.
Now It rides bad, as in every bump creates bump steer, and now it feels like it rocks side to size over bumps like blown shock on one side. And it still seems like it pulls to the left.
How much room is between the bump stop and the A-arm It looks like I got 1/4-1/2in. Maybe it bottoming out on one side before the other side creating the rocking. I looked at the t bar bolts and it does not look like they adjusted them.
My ideas maybe new parts loosened up the steering so bumps affect it more, could be blown shock. What do you think?
Thanks for the help in advance.
Old Oct 1, 2011 | 11:31 AM
pettyfog's Avatar
Bump steer is usually sway bar* or shock related.
-- OR lift or drop suspension taking the geometry out of specs. IE... if inner tie rod is too far off the height of outer ends, it can cause bump steer.
But subject says 'alignment done'... when? before or after all this.
Try reading that as if you had no knowledge of anything done.
*BTW: Everyone who reads this.. DISCONNECT one side's SWAY BAR LINK before you do T-Bar adjustments!
Old Oct 1, 2011 | 08:23 PM
kristoph30's Avatar
kristoph30 is on a distinguished road
Ive seen a bad idler arm cause this also.
Old Oct 2, 2011 | 12:36 AM
Karcinagin's Avatar
alignment was last thing done
blazen_red_4x4
Oct 13, 2014 12:39 PM
wgg
Aug 29, 2011 11:30 AM
Rockalot19822008
Mar 2, 2011 12:21 PM
jspafford
Jun 10, 2009 04:51 PM
Bad Ramer Jamer
Sep 27, 2008 03:55 PM
