where are cheap lift kits??
Old Aug 5, 2012 | 10:21 AM
Bluebeastblazer57's Avatar
Bluebeastblazer57 is on a distinguished road
Default where are cheap lift kits??
Im looking for cheap lifts and would like some help to guide me where to go for a good cheap lift that will hold up to some beating
Old Aug 5, 2012 | 10:32 PM
USMC3782's Avatar
USMC3782 is on a distinguished road
i guess you should start with a few things:
What do you consider cheap?
Are you doing it yourself or having a shop install?
How high do you want to go?
How long do you want it to last?
ton of good advice on the forum but a little more specifics can go a long way. Also the specifics of your vehicle as it is now would help.
Old Aug 7, 2012 | 01:30 AM
well cheap is under 500 dollars. i would install myself and i would like it to last a while. any ideas?? I have a 96 chevy blazer non-zr2.
Old Aug 7, 2012 | 03:29 AM
247monster's Avatar
torsion key and shackle lifts- 80 bucks TORSION BAR KEYS & SHACKLES LIFT KIT 1994 - 97 4X4 Chevy S10 Blazer 600 | eBay
2in body lifts - 150 bucks - http://www.ebay.com/itm/PERFORMANCE-...ht_3091wt_1098
full on rough country suspension lift - 430 bucks 82-04 S10,S15 Pickup,Blazer,Jimmy,ZR2 & Non-ZR2 4WD 2.5" Rough Country Lift Kit | eBay
Old Aug 7, 2012 | 08:11 AM
neo71665's Avatar
I would suggest cranking the factory t-bars the 1.5 inch you can safely go. Use shackles on the rear. Then order a body lift.
Aftermarket keys are a waste of money. The factory keys cranked lift it the same amount. Past 1.5 inches you stress the ball joints and cv axles cause them to wear out faster. Since all they do is reposition the starting point higher they crank the t-bar exactly the same, the ride is the same as cranked factory bars.
The guys around here are still having cv shaft and ball joint problems with the rough country lift. I said it wasn't worth the money when it came out and still stand by that.
Old Aug 7, 2012 | 03:40 PM
247monster's Avatar
^ need that sign for my shop lol
i was looking at the shackle and key but my blazers pretty rusty and i have a feeling it will be a total nightmare lol so im just goina stick with the some taller tires for now lol
Old Aug 7, 2012 | 06:25 PM
rodeofan5656's Avatar
rodeofan5656 is on a distinguished road
i plan on goin with the Shackle and Torsion Arm/Key lift from eBay. i wanna crank the keys to 3'' in front and do an add-a-lift to the rear, plus the longer shackles. that should give my 3 total inches of lift, without screwin with the body
Old Aug 7, 2012 | 06:45 PM
neo71665's Avatar
You crank the front over 1.5 inches you better buy a lot of spare ball joints and cv axles. Don't forget a good jack and jackstands. I'd also suggest getting an air compressor and air tools if you don't have them. I wouldn't bother putting loctite or antiseize on anything frontend related, its not gonna have a chance to come loose or rust up as much as you about to be tearing it apart to replace parts.
Old Aug 9, 2012 | 10:49 AM
seanmurphy265's Avatar
seanmurphy265 is on a distinguished road
JC Whitney has a closeout price on a Rough Country 2" suspension lift.
Rough Country Suspension Suspension Lift Kit - JCWhitney
Old Aug 9, 2012 | 07:50 PM
abig84's Avatar
sawzall will allow you to fit up to 35 inch tires
