At whits end with noise!!!
Old Aug 13, 2008 | 04:56 PM
laboone's Avatar
laboone is an unknown quantity at this point
Default At whits end with noise!!!
I just searched the forum for four hours and I've already done everything I have found that should fix the problem noise. I need help before I go insane! Its a 2000 X Blazer that has a popping, thud type of noise when I hit certain bumps. The noise is really bad on dirt roads with washboard erosion and seems to be in the front end. So far I have replaced the tires, control arm bushings, axles, upper control arm bushings, lower ball joints, rotors, motor mounts,and the shocks(twice). I have also adjusted the Z-rod / torsion bars and checked the cross member. I have beat, tugged, and pried on every suspension part. I checked the hood hinges. Everything seems tight. The freaking noise is still there. Someone either help diagnose the problem or shoot me. I am loosing my mind over this! [sm=headbang.gif]
Old Aug 13, 2008 | 06:41 PM
Default RE: At whits end with noise!!!
How did you check the hood hinges?
Also, grab a hold of the shock and give it a shake. I had to really tighten the crap out of the upper shock bolt on my front shocks when I replaced them. They rattled like worn ball joints.
Old Aug 13, 2008 | 08:31 PM
Bigringtravis's Avatar
Bigringtravis is on a distinguished road
Mine has a knocking driver's side sway bar bushing! It's because the power steering lines leaked and the hydraulic fluid ate it up - along with the lower shield(Skid Plate.) It was quite the "snowball" effect.
Speed bumps really set it off!
Old Aug 14, 2008 | 08:32 AM
laboone's Avatar
To check the hood hinges I placed a couple of old rags to give some added pressure and the popping was still there. I grabbed the shocks and even used a pry bar, but they don't move. Theres not a whole lot less to replace. I'm sick of the noise and tired of wasting money. Got my first Blazer in 85' and have owned one ever since. I like it and dont want to get rid of the car. I have other cars, but this just seems to be my favorite toy.
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
brino1
Feb 25, 2011 08:05 PM
Chrismacster
Apr 2, 2009 06:57 PM
dlockett999
Dec 14, 2008 05:39 PM
