ZR2 rear end???
Old 12-12-2007 | 05:52 PM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
Default ZR2 rear end???
I was reading that a ZR2 rear end is a nice upgrade for non-zr2'srear ends, because its a 8.5" instead of 7.5" making it stronger. Just wanted to know if its a direct bolt in? Right now I have 3.42 gears so could I have 3.73/4.10 in back and 3.42 of front, or would that not work? And lastly would the front diff. from a ZR2 bolt right in so I could have matching gears and are the fronts of a ZR2 any stronger than in a stock 96 blazer 4-door? Sorry for all the questions, but any help would be great. Thanks
Old 12-12-2007 | 05:59 PM
mdehoogh's Avatar
Default RE: ZR2 rear end???
you cant really use two different gears in the front and the back... one axle would be spinning faster than the other = transfer case will die
Old 12-12-2007 | 07:14 PM
drperry's Avatar
The ZR2 axle is also a little wider, if I remember right...
Any 2nd gen Blazer with a 5 speed should have the 8.5" and the iron front diff.
Old 12-12-2007 | 07:29 PM
Thanks. Also since I currently have drum brakes on the rear, do I have to do anything to make the disc brakes on a ZR2 rear end work?
Old 12-12-2007 | 10:36 PM
Hanr3's Avatar
Yes, and good question.
You will need to change the master and the proportioning valve. Drums require less pressure then discs. Take them from teh donor truck.
Old 12-12-2007 | 11:24 PM
Idriveachevy's Avatar
Idriveachevy is an unknown quantity at this point
Are you hacking up a Zr2? if so, send me pm i want to tlak to you about some stuff.
Old 12-12-2007 | 11:25 PM
felonyblazer96's Avatar
felonyblazer96 is an unknown quantity at this point
i am hacking up a zr2 any info would be appreciated
[/align]
Old 12-13-2007 | 02:26 AM
ORIGINAL: Hanr3
Thanks, I had to do that on my camaro, butwasn't positive if it was the same for blazers.
Old 12-13-2007 | 02:27 AM
ORIGINAL: Idriveachevy
Nope, but I'm going to go junkyard shoping in the next week or two and see what I can find.
Old 12-13-2007 | 06:26 AM
drperry's Avatar
Well, if you insist on using an axle from a ZR2, then at least your rear wheels will stick out at least as far as the fronts, lol.
The track width of a ZR2 is wider, you might run into some issues with that.
I have the 8.5" diff, and I'm not a ZR2 [8D]
There's a few 4 doors that have it too... Jigg found one awhile back, lol, even had 3.42's in it.
