Zr2 suspension
Old Jan 17, 2011 | 01:04 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Default Zr2 suspension
This is probably a stupid question but is it possible to swap the suspension from a zr2 straight to a 4door Lt?
Old Jan 17, 2011 | 10:41 AM
AJBert's Avatar
no. no. no.
It wouldn't let me reply with just one "no".
Old Jan 17, 2011 | 11:18 AM
wlorton's Avatar
You could swap some components though....
Old Jan 17, 2011 | 11:28 AM
Benedict1337's Avatar
the only things you can really swap are the leafs, torsion bars, and torsion keys... everything else is different
Old Jan 17, 2011 | 11:59 AM
Red 96''s Avatar
I asked the same question a while back, here's the link
https://blazerforum.com/forum/lifting-tech-44/zr-2-suspension-43339/
Old Jan 17, 2011 | 01:01 PM
Ok that's kinda what I thought. I want to make the back end stiffer so if the zr2 leafs fit I was thinking about doing that or just adding a leaf. Thanks for the help
Old Jan 17, 2011 | 02:27 PM
ABN31B's Avatar
I had the same plans, but ended up going with what is commonly called a "bastard pack" where you essentially mix-and-match pieces of multiple spring packs to achieve what you want. i teamed it up with new shocks and a lift shackle, and now my blazer rides more truck-like in the back. worth looking into i guess.
Old Jan 17, 2011 | 02:44 PM
oh that sounds like a good idea. i dont really want to lift it a whole lot because i just bought standard 235 tires and a lift would make it look bad with the smaller tires i think. buying the tires is a interesting story too. the geniuses at discount tire sold me 31's and said they would fit with no rubbing at all. they put them on and i backed out of the garage and turned slightly and the tires started grinding so i pulled it right back in and had them put the 235's on. whats interesting is one of the guys there has a 00' Lt blazer with 31 M/T's with no lift or adjustment (so he claims) and they dont rub at all. i dont know how that can possibly work unless he only drives in a straight line..
Old Jan 17, 2011 | 06:15 PM
ABN31B's Avatar
dont open THAT can of worms man...
Old Jan 17, 2011 | 11:41 PM
they told me i could probably use a grinder and carve away at my body panels to get it to fit but i said no thanks.
