Zr2 suspension lifts
Old Nov 27, 2024 | 11:52 PM
Deniso's Avatar
Deniso is on a distinguished road
Default Zr2 suspension lifts
Looking for a suspension lift for my zr2 2001 chevy blazer 2dr that doesn't include more than 2" body lift or cutting fenders. I've heard a combo of two different ones to make one but am hoping there is a solution other than S.A.S. ?
Old Nov 28, 2024 | 02:15 AM
The ZR2 already is a bit higher and has the 31" tires so not many add a lift to these. The only readily available lift that I know of is the 2.5" lift from Rough Country. It retains the IFS. However, if I remember correctly, the 2.5" applies to non-ZR2 Blazers so that the ultimate lift with their kit is only 1.5".
https://www.roughcountry.com/product...lift-kit-242n2
Old Nov 28, 2024 | 11:26 AM
hurleyii's Avatar
hurleyii is on a distinguished road
I'm curious as to why the lift only gives 1.5" to a zr2. It just does t make sense unless it has to do with the rear leaf front mounting location.
Old Nov 28, 2024 | 12:53 PM
Part of the 2.5 inches of lift for the non-ZR2 Blazers is going to be from being able to replace the stock tires with the 31s that are stock on ZR2s. This alone can add 1 to 1.5 inches of clearance depending if you are running 235/70- R15 or 235/75-R15 tires now.
Deniso
Apr 9, 2021 11:08 PM
Red 96'
Lifting Tech
20
May 4, 2010 02:21 PM
Lifted02Blazer
Lifting Tech
Apr 20, 2009 08:33 PM
dubb_05
Oct 7, 2008 08:31 AM
rickyp3278
Apr 12, 2008 12:00 AM
