Street N Strip Post your vacation driving stories, day at the track, breakdowns, safety issues, driving techniques, unique driving conditions, etc. STREET RACING STORIES ARE STRICTLY PROHIBITED.
bigger diameter tires..faster?
Old Feb 28, 2006 | 01:20 AM
2001blazer's Avatar
2001blazer is an unknown quantity at this point
Default bigger diameter tires..faster?
ok so im lookin at 255/45r20 tires and i want to know if the take off/1/4 mile of the truck will be faster with the larger diameter tires i will have really heavy rims in the truck though aswell so im not sure if the weight would have anything to do with it but there 20x8.5 in. rims that weigh 37 lbs each so there a pretty thick chunk...what do u guys think
Old Mar 7, 2006 | 01:42 AM
Default RE: bigger diameter tires..faster?
Actually, the closer the rotational moment of inertia is to the outside diameter of the tire, the more difficult this tire/wheel combo will be to accelerate (and decelerate). So now since you have a large, heavy rim, your acceleration and braking will both suffer because of it. That is why just about anyone that does a big rim/tire combo upgrade should also attend to the braking concerns of the vehicle.
If the rotational moment of inertia were the same between your stock rim/tire and the ones you were switching to, but the new combo was larger in diameter, you would effectively change the overall gear ratio for the worse. This would make you loose speed off the line, but gain it at the other end of the track. Now would you gain enough at the opposite end to make up for the lost time at launch, probably not. You would most likely see a slower 1/4 mile time with an increased 1/4 mile trap speed. EX: stock you might see 17.1sec@79mph and with the larger rims you may see 17.8sec@83mph (completely made up numbers!).
Old Aug 28, 2006 | 12:03 AM
Tony Mantelli's Avatar
Tony Mantelli is an unknown quantity at this point
if your going to go with a bigger tire and want your acceleration to be the same then go with a lower gear the only drawback is that the lower the gear the less top end speed you will have but u will get there quicker and since you have a 4x4 you would have to do the same gear in front and rear i think you have 3.08 gears a good gear ratio would probably be like a 3.73 or even a little higher
Old Aug 28, 2006 | 03:08 AM
20Blazer00's Avatar
I have a 2000 LS and my stock ratio is 3.42 should be the same for '01. And he would have to go lower than 3.73's. I would guess something above 4.10's ??? but that is only a guess since I have not researched the diameter of the 20's.
There are sites out there that will help with that but I would do a search for them...
MacArthur
Tires and Wheels
Jun 14, 2011 08:51 PM
gmc004x4
Dec 16, 2009 09:07 AM
96chevblazer
Aug 25, 2009 05:43 PM
chris015
Jul 13, 2009 11:08 PM
1slowblazer
Street N Strip
34
Oct 11, 2007 06:34 PM
