Suspension Tech Have a question about modifying your suspension? Ask it here.
2.5 in lift, wheel spacers
Old Dec 4, 2013 | 08:47 PM
98jimmyengine's Avatar
98jimmyengine is on a distinguished road
Default 2.5 in lift, wheel spacers
im looking at getting a rough country 2.5 inch lift for my 98 gmc jimmy, im also looking to get wheel spacers also for it and new wheels, whats the best size wheel spacers and wheel back spacing sizes to get, please help!
Old Dec 5, 2013 | 09:06 AM
El_Beautor's Avatar
Your question is very subjective. Some people like their tires to stick way outside the fenders, and get very low backspacing wheels. Others like to keep as close to factory specs as possible so they maintain normal wear and driving characteristics, and there's a whole range in between. What type of look and function are you going for? I'd suggest you browse through the build section to find a Blazer that has the look you're trying to achieve and then pick a similar build style.
You also need to let us know if you have a 2 door or 4 door Jimmy, if it's a 4x4 or 2wd, if it's a ZR2, and what size tires you want to use, etc.
Old Dec 5, 2013 | 09:02 PM
i was looking to just wident the stance a little bit but keep it looking nice, nothing crazy wide just a few inches or so, i was gonna keep with stock tires 235-75-15 but maybe get 31`s sometime, wasnt sure how wheel spacers and the backspacing affected all of it,
Old Dec 6, 2013 | 09:57 AM
El_Beautor's Avatar
Wheel spacers will widen your stance, as will lower backspaced rims. If you are getting new rims don't bother with the spacers and just get rims with less backspacing. If you have a 4x4 then the stock backspacing is 6". Lots of people put 2wd rims on cause they have 4.5" backspacing which gives it the wider stance. Many aftermarket rims will have around 4.5" of backspacing too.
Old Oct 6, 2018 | 05:43 AM
Freewheel's Avatar
Freewheel is on a distinguished road
Take a look at mine, i've got just that setup, 2.5 inch RC lift and 2" /side rear spacers 1"/side front spacers... Std wheels and 31x10.5 tires (mounted they measure just under 32"
Old Oct 6, 2018 | 09:55 AM
Default 2.5 lift, 1.5 rear spacer, bigger offset rims.
I also have an add a leaf on the rear, so its an extra 2-3 inch higher then the lift.
Old Oct 6, 2018 | 09:57 AM
And my tires are 235/75r15. I will be going to 30-31 next summer/ winter when I need new tires.
Old Oct 6, 2018 | 12:25 PM
For my 2" lift (see details below) I decided I did not want to tempt fate too much by only installing 1.25" spacers on the rear. Looking at my front end last weekend, I did notice that a thin spacer on the front with the RC upper control arms might prevent the inside of my stock rims from touching the sides of the upper control arms when they are deflected fully down (i.e. when there is no load on the suspension) and the wheels are turned to full stop with the steering wheel.
BTW, the choice of the 1.25 spacers was to "square up" the stance by bringing the rear tires out to about the same point as the front.
Old Oct 7, 2018 | 10:35 AM
Freewheel's Avatar
Just what im lookin for to see, mine has the negative rake so i just ordered a pro com add-a-leaf kit to strighten things up a bit! Cheers!
lazyboyjake
Tires and Wheels
May 5, 2015 02:41 AM
BRoss99
Tires and Wheels
Aug 29, 2014 07:00 AM
1997 Gmc Jimmy
Tires and Wheels
Nov 28, 2011 06:53 PM
Frenchyap30
Tires and Wheels
Aug 16, 2009 09:17 PM
DJ 4x4
Tires and Wheels
Jan 10, 2009 02:09 PM
