Suspension Tech Have a question about modifying your suspension? Ask it here.
2 inches more
Old Mar 11, 2019 | 05:14 PM
OlympicWhiteZr2's Avatar
OlympicWhiteZr2 is on a distinguished road
Default 2 inches more
I've installed a set of lift shackles on the rear of my 2000 Zr2, along with new leaf springs. Now it sits with a 9 inch fender well gap in the rear, but barely 7 inches up front. I already installed the Rough Country upper control arms and they dont provide enough adjustment for that much of a torsion bar crank... does anyone know how to get that 2 inches more height?
Old Mar 11, 2019 | 05:30 PM
Did you apply the torsion keys, and a drop braket for the front diff? Other then those, I think maybe an option of a body lift.
Old Mar 11, 2019 | 06:24 PM
do the keys make that much of a difference? I haven't installed them, but with a torsion bar crank and control arm adjustment there is still some extreme positive camber.
Old Mar 11, 2019 | 06:54 PM
You do get a little more height, the hole itself is at a different degree.
I think it's offset about 15-20 degrees, which will give you the extra 2.5 inch in height...
Old Mar 11, 2019 | 07:07 PM
Don, I'm gonna give it a shot... I have all the parts already, I had become discouraged when the camber was still way out of spec.
Old Mar 11, 2019 | 07:12 PM
Just remember when taking the stock keys off, to mark where the extended part is. Miss alignment and you will have a real hard time adjusting them, as well as throwing off the toe in/out
Old Mar 12, 2019 | 04:23 AM
Wheela's Avatar
Wheela is on a distinguished road
Just add a little weight to the back, some recovery gear and supplies. That should lower the rear a little thus bringing the front closer to being level!
I had the opposite problem with mine after the lift, the front sat a bout 1.5" higher than the rear, tossed on an Add-a-leaf and that helped about an inch and with the winch mounted up front that helped level her out
Old Mar 12, 2019 | 03:16 PM
Wheela suggested I install the t-bar keys and guess what? I got the height inwas looking for... the truck now has a slight rake, fender gap is 8.5 in the front and 8.75 in the rear!!
Old Mar 12, 2019 | 03:32 PM
cleburne red's Avatar
Nice! Looks good!
Old Mar 12, 2019 | 06:53 PM
Thanks, Cleburne
