Suspension Tech Have a question about modifying your suspension? Ask it here.
6 lug conversion
Old May 30, 2014 | 09:35 PM
kmotorhead87's Avatar
kmotorhead87 is on a distinguished road
Smile 6 lug conversion
So I have a 96 chevy blazer lt 4 dr 4x4 with a 4.6 I am doing a 5.7 swap with a 2" body and 4" suspension lift but I want it to be 6 lug so my question is the 96 Tahoe/1500 im using as my donor will the front hubs bolt up to my spindles with the cv axle swap or will I have to swap the whole spindle out as well???? thks for the help in advance
Old May 31, 2014 | 09:21 PM
roypai's Avatar
roypai is on a distinguished road
try it and post up - i'm intrigued - you thinking of adaptors on the rear or an axle swap?
(and if you have a 4.6L in that thing then its a ford)
Old May 31, 2014 | 09:43 PM
oops ya 4.3 but my plans were to swap front hubs and the cv axles and rear axles but the rear axle has the same gear ratio as the blazer I think the rear diff is wider so I might have to install the whole rear axle but as I go I will update
ckroll98
Tires and Wheels
Oct 25, 2013 08:42 PM
thibault116
Tires and Wheels
Apr 10, 2013 09:35 AM
Ray Gotti
Jan 18, 2012 11:16 PM
mikes87k5
Sep 4, 2010 12:41 AM
buddanicholson101
Tires and Wheels
Aug 17, 2010 05:16 PM
