Suspension Tech Have a question about modifying your suspension? Ask it here.
Bag & Destroy
Old Jan 19, 2007 | 09:02 PM
thegr81's Avatar
Default RE: Bag & Destroy
the biggest thing that u have to keep in mind is whether or not to body drop and also what size rim u want to lay out on that will give u the price tag of ur bag job.
Old Jan 19, 2007 | 09:10 PM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
This is my roommates bagged S-10, It has the weld in c- notch, the 5 link, carrier bearing x-member, but BUT ALOT of cutting was done and alot of welding.
Its also wise to get a high amp alternator and a redtop or two.
Old Jan 20, 2007 | 10:04 AM
mikeywaynebygod's Avatar
mikeywaynebygod is an unknown quantity at this point
or three. if you can find a good york compressor, get it. belt driven compressors build up air alot faster than your conventional compressor. and remember, the bigger the air tank, the more you can play
Old Jan 20, 2007 | 10:29 AM
ORIGINAL: mikeywaynebygod
Oh yeah another thing, DO NOT BE CHEAP, get your air dryers and wire in an override switch, itll save you alot of aggrivation on cold mornings when your leader hose and valves freeze up.
I hate to say it but check out s10forum.com its a site with thousands of bagged members on it. Just do a search first, if not you will get flamed and bashed for not searching first. Kinda crappy but thats the way that site works, i guess.
Are you 4x4?
Old Jan 20, 2007 | 10:32 AM
ORIGINAL: LORCLAS
I have the Blazer bolt-in notch from suicidedoors.
http://www.suicidedoors.com/BlazerBolt-inC-Notch.php
Even with my static drop I had a notch.
My front bags are just the standard S-10 front bag kit from Suicidedoors. Running Airlift bags. Rear is all custom. Suicidedoors built the bars but that is it. All the rest was fabed.
My ride is as low as you can go without cutting the floor.
Remeber the 4 "B's".....Bags. Bi***** beer and body drops.
Old Jan 25, 2007 | 12:49 AM
b_evans06's Avatar
b_evans06 is an unknown quantity at this point
Cando specialties makes a bolt on 4 link for blazers with the gas tank in the rear. If I link the page it goes to the home page of their site but check out http://candospecialties.com/ and go to 4links and its on the very bottom. But for the rest Id go to suicidedoors.com and check out their kits. You can build your own air management kit with whatever parts you want and save some money.
932d
Lowering Tech
Jan 20, 2010 10:14 PM
Zane25-hitch
Jan 16, 2010 11:54 PM
boomtruck97
Suspension Tech
Jun 29, 2006 10:00 AM
knightrain420
Suspension Tech
Nov 17, 2005 12:14 AM
Headcas3
Suspension Tech
Jul 26, 2005 10:29 PM
