Suspension Tech Have a question about modifying your suspension? Ask it here.
bagging a 4x4?
Old Nov 22, 2006 | 02:08 AM
jagblazer01's Avatar
Default RE: bagging a 4x4?
i have a question....how much was all that if u dont mind me asking cuz now its gained my attention lol
Old Nov 22, 2006 | 02:38 AM
mikeywaynebygod's Avatar
mikeywaynebygod is an unknown quantity at this point
lol, exactly. the local place that i called said it'd cost me about 4k for parts, labor, and all that good jazz. they said i could crush full pop cans with it, so i dunno.
Old Nov 22, 2006 | 02:32 PM
simply2low4u's Avatar
simply2low4u is an unknown quantity at this point
1/4 or 1/2 what valves, lines, gauge line? I would go 1/2 fill valve, 1/2 line, 1/8 gauge line, and 3/8 dump.
All together the rear cost me about 250 in link, 120 for bags, 50 for brackets and the notch. The front i paid 250 for tube arms, 160 for bags, and a couple hundred for the brackets. Overall with redoin the rear and completely doin the front around 2500. Not including the tank, valves, or compressor
Old Nov 22, 2006 | 03:45 PM
slammins15's Avatar
slammins15 is an unknown quantity at this point
x
Old Nov 22, 2006 | 06:56 PM
its safe, the torsion bars are just the front suspension, what are you worried about? You can take out the crossmember and still it will be plenty strong. The bars just hook into the lca.
Old Nov 22, 2006 | 07:26 PM
well, one day in the far off future when i learn to weld and all that good stuff, maybe i'll try that.
Old Nov 22, 2006 | 10:36 PM
slammins15's Avatar
x
Old Nov 23, 2006 | 05:35 PM
my brother said the same thing, and he too said it'd be impossible. he's not a fan of anything not deisel, though. i'll probably end up getting pissed and just do a frame swap.
Old Dec 20, 2006 | 12:27 AM
yobee's Avatar
yobee is an unknown quantity at this point
in regards to slammins15. the vehicle will be bagged. therefore it is ok to remove the torsion bars. they are the suspension from the factory yes. but they will be removed and airbags will be placed instead on top of the upper control arm so that the 4x4 will still function, the airbag will act as the spring and shock in this case, some people choose to run an airbag and a shock still. and the steering tie rods will still hold the spindle like stock, but you are doing away with the torsion suspension and adding an air suspension.
Old Dec 20, 2006 | 03:32 AM
well, if i was gonna do it, i'd leave just put drop shocks on it. i don't know about all the rest because haven't heard of people doing it.
