Suspension Tech Have a question about modifying your suspension? Ask it here.
Bent right suspension???
Old Apr 10, 2013 | 10:22 PM
lityjohn701's Avatar
lityjohn701 is on a distinguished road
Default Bent right suspension???
Blazer was wrecked before we bought it. Don't think the frame is bent but now with the new wheels this is noticeable. Font sway bar bolt is bent on the side it was wrecked and isn't straight up from the lower a arm mount not sure what wrong with it. Here some pics. The left side (point of view from front of blazer) is In way more than the right side
Old Apr 10, 2013 | 10:24 PM
On my iPad and don't know hot to inset more than one pic this is the right side sorry!
Old Apr 11, 2013 | 01:47 PM
Diaita's Avatar
Might be worth bringing it to an alignment shop, they have the tools to set it up properly. A bad wheel bearing will make the tire lean in a little too.
Old Apr 11, 2013 | 02:03 PM
I doesn't look like its leaning but I'm no pro! Well be taking it to the shop for an alignment soon ill put up a pic of the front sway bar also
Old Apr 11, 2013 | 05:04 PM
This is the side that is in more isn't the sway bar supposed to be right under the hole for the bolt
Old Apr 11, 2013 | 05:31 PM
rexazz2's Avatar
It could be an optical illusion depending on the body alignment
Like Diata said , take it to a reputable alignment shop if your concerned
And yes that sway bar link kit is bent , they are less than $20 to replace
Old Apr 11, 2013 | 05:40 PM
Diaita's Avatar
The bent link may be a part that was forgotten when it was repaired, but the alignment of the A-arm and the sway bar don't look to be too far off.
Old Apr 11, 2013 | 05:50 PM
So should I just get a sway bar from a local pull a part?
Old Apr 11, 2013 | 06:51 PM
rexazz2's Avatar
sway bar itself is spring steel so it should be ok
You can clearly see the sway bar link itself is bent , the bolt that runs threw it should be perfectly straight
Old Apr 11, 2013 | 06:55 PM
Diaita's Avatar
You just need the link, it's the vertical bolt and bushings that connect the sway bar to the lower control arm. An auto parts store should have one.
