Suspension Tech Have a question about modifying your suspension? Ask it here.
big brake kit
Old Oct 17, 2007 | 05:42 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default big brake kit
Ive done some searching around and havent really come across anything. Is there a decent big brake kit around for a 1st gen blazer with 4x4? are they ok to use with stock rear drums? Will I need to upgrade the nrake cylinder as well? Thanks in advance!
Old Oct 18, 2007 | 05:55 PM
thegr81's Avatar
Default RE: big brake kit
with a big brake kit your going towant to do a disc conversion to the rear and if you haven't allready checked there is baer, willwood,brembo,superlite6 check all those out and maybe you will find what your lookin for
Old Oct 18, 2007 | 07:27 PM
bobditts's Avatar
is it necessary to do that? I just want to have better stopping ability than stock. Do I have any other options?
Old Oct 18, 2007 | 09:27 PM
thegr81's Avatar
you can just swap out the front with a big brake kit or for better stopping swap all pads to ceramic pads and change the drums and rotors out with ceramic style rotors and drums check with checker or kragen whichever you have were your at for raybestos i use them and there sweet for better stopping without a big brake up grade the reason i would go to a big brake kit is if i went to a 20' rim or bigger then you would need a bigger brake kit
Old Oct 18, 2007 | 10:11 PM
bobditts's Avatar
Thanks for the help. Ill check into the ceramic pads and shoes.
Old Oct 19, 2007 | 08:54 PM
thegr81's Avatar
no problem anything to help and you should like the ceramic set up you wont want to go back to metallic or semi metallic or organic the bonus of ceramic pads is no black brake dust
Old Oct 19, 2007 | 11:17 PM
bobditts's Avatar
ive got ceramics on my sedan. They are nice. I never even thought about what might be on the blazer untill you mentioned it. Thanks again!
Old Oct 19, 2007 | 11:34 PM
thegr81's Avatar
no problem any other questions about other parts just ask i have been around the parts block quite a bit just let me know
bigdaddykane93
Feb 24, 2013 02:30 PM
Jkrumm
Lifting Tech
Feb 17, 2011 04:35 PM
ericthughes
Lifting Tech
Oct 13, 2010 10:56 PM
butters
Sep 29, 2008 06:40 PM
2001blazer
Tires and Wheels
Mar 9, 2006 02:39 PM
